    Different behavior on Mac for Commanddata options
    r23python
    6 Posts 3 Posters 758 Views 1 Watching
    • P Offline
      pim
      I have a commanddata plugin that has options enabled using the PLUGINFLAG_COMMAND_OPTION_DIALOG flag.
      On the pc everything is ok, I see the option icon in the command and I can select it.
      However, on the mac (Catalina 10.15.6) I do not see the option icon and when I click the command (the commanddata plugin), it goes directly to ExecuteOptionID() and not to Execute()
      Here the stripped code
      import os
      import sys
      from c4d import gui, plugins, bitmaps, documents
      from c4d import utils
      PLUGIN_ID_MESHBOOLEAN_COMMAND_SUBTRACT = 1039980
      class MyOptionsDialogSUBSTRACT(gui.GeDialog):
          OK = False
          def InitValues(self):
          def CreateLayout(self):
              self.SetTitle("MeshBoolean Command SUBSTRACT Test 01")
              self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL)
          def Command(self, id, msg):
              if (id == 1):
                  self.OK = True
                  self.Close()
              if (id == 2):
                  self.OK = False
                  self.Close()
      class MESHBOOLEANSUBSTRACT(plugins.CommandData):
          dialog = None
          def Execute(self, doc):
              print ("Execute")
              print ("Done test")
              return True         #end plugin
          def ExecuteOptionID(self, doc, plugid, subid):
              print ("ExecuteOptionID")
              if self.dialog is None: self.dialog = MyOptionsDialogSUBSTRACT()
              self.dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID_MESHBOOLEAN_COMMAND_SUBTRACT, defaultw=500, defaulth=120)
              print ("OK: ", self.dialog.OK)
              if (self.dialog.OK):
                  self.Execute(doc)
                  self.dialog.OK = False
          pluginString = "MeshBoolean Command Subtract"
          bmp = bitmaps.BaseBitmap()
          fn = os.path.join(dir, "res", "command subtract.png")
          bmp.InitWith(fn)
          okyn = plugins.RegisterCommandPlugin(id=PLUGIN_ID_MESHBOOLEAN_COMMAND_SUBTRACT, str="#$1 " + pluginString, info=c4d.PLUGINFLAG_COMMAND_OPTION_DIALOG, help="MeshBoolean Command", dat=MESHBOOLEANSUBSTRACT(), icon=bmp)
          if (not okyn):
              print("Error initializing " + pluginString)
      • P Offline
        pim
        What I also notice, is that - on the mac - when I do a customize command and add the plugin as an icon to my interface, the option icon is there and it works like expected.
        • C4DSC Offline
          C4DS
          I guess you encounter the same issue as mentioned here.
          Short answer:
          When the window has it's own menu then the option's cog wheel should work as expected.
          Not so if it is the Finder's main menu.
          Which also explains why dropping an icon in the interface does work as expected. As the issue seems to be the main menu in Finder.
            thanks for linking the other thread and yes, that's the difference with the mac menu on the osx bar.
            On those menu we can't add the cogwheel so we choose to display the option by default (with was the old behaviors)
            • P Offline
              pim @Manuel
              @m_magalhaes said in Different behavior on Mac for Commanddata options:
              Ok, clear.
              Please mention it in the documentation.
              -Pim
                hi
                That's already mentioned in our application documentation.
                https://help.maxon.net/us/index.html#PREFSINTERFACE-PREF_INTERFACE_MAIN_GROUP
                Where do you think we should mention it ?
