    Documentation for 6.3 ?
    3 Posts 0 Posters 470 Views
      On 27/08/2003 at 06:28, xxxxxxxx wrote:
      Cinema 4D Version:   6.3
      Hallo,
      I need the C++ documentation for C4D 6.3. I can only find the
      7.3 and the 8.1 docu.
      thanks in advance, Matthias
        On 27/08/2003 at 09:06, xxxxxxxx wrote:
        there were no C++ docs for 6.3, but it should mostly be the same as 7.3.
          On 27/08/2003 at 10:57, xxxxxxxx wrote:
          Thanks David,
          Unfortunatly I spotted differences or I am not sure.
          Are there diffreences between the following Plugin objects
          6.3                7.3
          CPluginKey - PluginKey
          CPluginSequence - PluginSequence
          CPluginTrack - PluginTrack
          I like to convert the MorphMixer from the 7.3 SDK to 6.3.
          I get errors at compiling because the PluginKey, -Sequence, -Track
          objects are not declared. I looked into the animplug header file
          and found that they called CPluginKey, -Sequence, -Track there.
          In MorphMixer.cpp is also "m.flags" MenuPlugin structure member
          but not in the 6.3 MenuPlugin header. I have tried to add this
          member and changed also the names of the plugin classes in
          the "MorphMixer.cpp". I can now compile fine and run the plugin.
          It works except the Animation. It records nonsense.
          Can someone help me please ?
          I would really like to use this plugin.
          best regards, Matthias
