    PRIM_CIRCLE_RADIUS
    7 Posts 0 Posters 866 Views
      On 25/08/2003 at 13:04, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;  Mac OSX  ;
      -- how can I retrieve the simple radius of a spline object.
      "PRIM_CIRCLE_RADIUS" (!)
      help is greatly appreciated.
        On 28/08/2003 at 00:08, xxxxxxxx wrote:
        Mmh, frankly I have no idea, what your are asking...
        Maybe you could elaborate your question a bit more?
        Kabe
          On 28/08/2003 at 00:53, xxxxxxxx wrote:
          thanks for your reply,
          I have a spline object -- a circle ( --> used for an extrude object). I have dozens of expressions applied to objects which ideally all relate to the size of the circle object. Yet I'd have to change vars in all exp.-- which is no good!
          and now the question -- in slow:
          -- how can I retrieve the radius of a Circle object?
          similar to 'a=vObj->GetScale...'
          in SDK is mentioned "PRIM_CIRCLE_RADIUS" (!) as a container ID, however I don't get the clue how to use this information.
          a global variable (e.g. var Rad=10), if possible declared in one expression to which all other exp. relate to would help too, however I miss the information how to declare a variable globally.
          mk
            On 28/08/2003 at 01:06, xxxxxxxx wrote:
            You have to get the container of the object with "var bc = obj->GetContainer()". Then you can get the value with "var r = bc->GetReal(PRIM_CIRCLE_RADIUS)".
              On 28/08/2003 at 01:54, xxxxxxxx wrote:
              thanks for the quick response!
              I inserted this code:
              var bc, r, obj;
              obj=vDoc->FindObject("Circle3");
              bc = obj->GetContainer();
              r = bc->GetReal(PRIM_CIRCLE_RADIUS); /*errror message*/
              'r' would be the var to deal with but it doesn't work:
              "Member not found"
              -> and I surley have a Circle Object 'Circle3' in the object manager...
              I'd appreciate your reply
              mk
                On 28/08/2003 at 04:00, xxxxxxxx wrote:
                Oops, I guess GetReal() is called GetFloat() in C.O.F.F.E.E.
                  On 28/08/2003 at 05:22, xxxxxxxx wrote:
                  thanks very much,
                  -- that was great help!
                  mk
