    S22: c4d.MCOMMAND_SPLIT returns a Bool instead of a List, while it returned a list in R21 and earlier versions
    5 Posts 2 Posters 974 Views 1 Watching
    • AwesuusA Offline
      Awesuus
      Hey guys, i have a script which uses the c4d.utils.SendModelingCommand until recently this returned a list to me. https://developers.MAXON.net/docs/Cinema4DPythonSDK/html/modules/c4d.utils/index.html#c4d.utils.SendModelingCommand
      This function either returns a boolean, or a list. Up until R21 the following code returned a list to me. But as of S22 i get returned the bool true, which signifies it ran succesfully, but i cant seem to retrieve the list.
      Any help on how i can get the list ( by passing a parameter or anything else ) would be appreciated.
      Heres the related snippet of my code
      selId = []
          sel = op.GetPolygonS()
          for index, selected in enumerate(sel.GetAll(polyCnt)):
              if not selected: continue
              selId.append(index)
          allPolys = [n for n in allPolys if n not in selId]
          settings = c4d.BaseContainer()
          res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT,
                                      list = [op],
                                      mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
                                      bc = settings,
                                      doc = doc)
      after running this script, res is now true instead of a List
      many thanks in advance.
        Hi @Awesuus first of all welcome in the plugincafe community 🙂
        Unfortunately, I wasn't able to reproduce your result in S22 and we correctly had a list returned.
        So what's your exact Cinema 4D Version? ( I tested on S22.118).
        Could you upload the Cinema 4D file where you are experiencing this issue?
        Thanks in advance,
        • AwesuusA Offline
          Awesuus
          Hi Maxime,
          Thank you so much for your reply. I also work in S22.118.
          Here's the whole script that I'm trying to get to work:
          from c4d import gui,utils
              if op.GetType() != c4d.Opolygon : return
              polyCnt = op.GetPolygonCount()
              allPolys = range(polyCnt)
              doc.StartUndo()
              null = c4d.BaseObject(c4d.Onull)
              null[c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME]+"_Segments"
              null.SetMg(op.GetMg())
              cntr = 0
              while allPolys:
                  settings[c4d.MDATA_FILLSEL_START_POLY] = allPolys[0]
                  utils.SendModelingCommand(command = c4d.ID_MODELING_FILL_SELECTION_TOOL,
                                              list = [op],
                                              mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION,
                                              bc = settings,
                                              doc = doc)
                  selId = []
                      selId.append(index)
                                              list = [op],
                                              bc = settings,
                                              doc = doc)
                  res[0][c4d.ID_BASELIST_NAME] = op[c4d.ID_BASELIST_NAME]
                  res[0].InsertUnderLast(null)
                  res[0].SetMg(op.GetMg())
                  sel.DeselectAll()
                  cntr += 1
              doc.InsertObject(null)
              doc.AddUndo(c4d.UNDOTYPE_NEW, null)
              doc.EndUndo()
          What I'm trying to get it to do is explode the mesh by edge selection, so that it creates a new null with the separate objects. The c4d file below is just a scene with a sphere with edge selections.
          test.c4d
            Thanks for the complete code, the issue is not located in the MCOMMAND_SPLIT but in the ID_MODELING_FILL_SELECTION_TOOL, within the S22 development cycle, parameters IDs changed but the new ones were not exposed to Python (I've created a bug report) so you need to hardcode them, like so
            startPolyID = c4d.MDATA_FILLSEL_START_POLY if c4d.GetC4DVersion() < 21600 else 1100 # MDATA_FILL_POLYGON_INDEX in C++
            selectionTypeID = c4d.MDATA_FILLSEL_SELECTION if c4d.GetC4DVersion() < 21600 else 1110 # MDATA_FILL_SELECTION_TYPE in C++
            And here your code adapted to work
                doc.StartUndo()
                cntr = 0
                while allPolys:
                    settings[startPolyID] = allPolys[0]
                    settings[selectionTypeID] = c4d.SELECTION_NEW # Or SELECTION_ADD or SELECTION_SUB
                                                list = [op],
                                                bc = settings,
                                                doc = doc)
                    selId = []
                        selId.append(index)
                                                list = [op],
                                                bc = settings,
                                                doc = doc)
                    sel.DeselectAll()
                    cntr += 1
                doc.EndUndo()
            AwesuusA 1 Reply Last reply Reply Quote 1
            • AwesuusA Offline
              Awesuus @m_adam
              Thank you so much, this works like a charm!!!
