    Set Xray in GetVirtualObjects()
    6 Posts 3 Posters 926 Views 2 Watching
    • RenatoTR Offline
      RenatoT
      Hi all, i'm trying to generate an XRAY pyramid inside the GetVirtualObjects() without luck.
      Here my source code:
      		BaseObject* pyramid = BaseObject::Alloc(Ocone);
      		if (pyramid) {
      			BaseContainer* cone_bc = pyramid->GetDataInstance();
      			const Float pyra_height = 0.75;
      			const Vector v1 = Vector(0.0, 1.0, 0.0);
      			const Vector v2 = Vector(1.0, 0.0, 0.0);
      			const Vector v3 = Vector(0.0, 0.0, 1.0);
      			const Vector center = bot_pos + Vector(0.0, pyra_height, 0.0);
      			const Matrix mg = Matrix(center, v2, v1, v3);
      			pyramid->SetMg(mg);
      			cone_bc->SetFloat(PRIM_CONE_TRAD, mid_lower * supp_scale);
      			cone_bc->SetFloat(PRIM_CONE_BRAD, mid_lower * 2.0 * supp_scale);
      			cone_bc->SetFloat(PRIM_CONE_HEIGHT, pyra_height);
      			cone_bc->SetFloat(PRIM_CONE_HSUB, 1);
      			cone_bc->SetFloat(PRIM_CONE_SEG, subdivision);
      			cone_bc->SetBool(PRIM_CONE_CAPS, true);
      			cone_bc->SetInt32(PRIM_CONE_CSUB, 1);
      			cone_bc->SetInt32(PRIM_CONE_FSUB, fstep);
      			// Try to set Xray ---------------------------
      			ObjectColorProperties prop;
      			pyramid->GetColorProperties(&prop);
      			prop.xray = true;
      			pyramid->SetColorProperties(&prop);
      			pyramid->SetParameter(ID_BASEOBJECT_XRAY, GeData(TRUE), DESCFLAGS_SET_0);
      			pyramid->Message(MSG_UPDATE);
      			// Try also with Container -------------------
      			cone_bc->SetBool(ID_BASEOBJECT_XRAY, true);
      			doc->InsertObject(pyramid, ret, nullptr);
      Thanks in advance
      Renato T.
      • CairynC Offline
        Cairyn
        I just checked with a Python generator, and it works, so at least it is not a general problem in virtual objects
            pyramid = c4d.BaseObject(c4d.Ocone)
            if pyramid == None: return None
            pyramid[c4d.PRIM_CONE_SEG] = 4
            pyramid[c4d.ID_BASEOBJECT_XRAY] = True
            return pyramid
        (but maybe I don't get your code; why are you inserting the object into the doc instead of returning it? I may be looking for the wrong context here)
        • RenatoTR Offline
          RenatoT
          Thanks Cairyn for the test.
          Yes, is a right question 🙂 ... let me check.
          • RenatoTR Offline
            RenatoT
            Ok, I miss to use OBJECT_USECACHECOLOR. I found it on this older post:
            https://developers.maxon.net/forum/topic/6674/7275_setting-xray-for-virtual-objects/8
            • r_giganteR Offline
              r_gigante
              Hi @RenatoT thanks for reaching out us.
              By looking at the code it's clear that your intent is to change the visual appearance of a portion of the cache and this can only be done registering the ObjectData with OBJECT_USECACHECOLOR. This, at the same time, comes with the drawback that the user can't change anything about the visual appearance of the object from AM.
              Different could be to set the ID_BASEOBJECT_XRAYparameter's value intercepting the MSG_MENUPREPARE but in this case, while the user retains the option to change the visual appearance, the whole geometry of the cache is affected.
              	def GetVirtualObjects(self, op, hh):
              		res = c4d.BaseObject(c4d.Osphere)
              		if res is not None:
              			if pyramid is not None:
              				pyramid.InsertUnder(res)
              		return c4d.BaseObject(c4d.Onull)
              	def Message(self, node, type, data):
              		if type==c4d.MSG_MENUPREPARE:
              			node[c4d.ID_BASEOBJECT_XRAY] = True
              Last but not least, be aware that you're misusing the BaseDocument::InsertObject(): for the scope of inserting the pyramid under the object returned by the ObjectData::GetVirtualObjects() it's more appropriate to use GeListNode::InsertUnder()
              Cheers, R
              • RenatoTR Offline
                RenatoT
                Thanks R, the insert was an error, i already corrected. OBJECT_USECACHECOLOR work as expected 🙂
                Renato
