    Getting and setting frame range from RenderData
    2 Posts 2 Posters 940 Views 1 Watching
    • N Offline
      nicholas_yue
      I read that I can get the RenderData object via
      rdata = doc.GetActiveRenderData()
      I see that frame range values are documented here
      https://developers.maxon.net/docs/py/2023_2/modules/c4d.documents/RenderData/index.html?highlight=renderdata
      RDATA_FRAMEFROM
      RDATA_FRAMETO
      RDATA_FRAMESTEP
      • r_giganteR Offline
        r_gigante
        Hi @nicholas_yue thanks for reaching out us.
        Although I'm not sure if your post was meant as a question or as a statement I'm going, nevertheless, to share some thoughts.
        The data you're looking for are stored in the RenderData BaseContainer and you can set/get them using the usual method.
        A full exmaple is available on PluginCafe Github Repo.
        Put down in words the code might looks like something as:
        def printRDataInfo(in_rdata):
            # BaseTime values are printed as frame
            print in_rdata[c4d.RDATA_FRAMEFROM].GetFrame(doc.GetFps())
            print in_rdata[c4d.RDATA_FRAMETO].GetFrame(doc.GetFps())
            print in_rdata[c4d.RDATA_FRAMESTEP]
        # Main function
            # retrieve the RenderData instance
            #just print the default values
            print "default rdata from/to/step values"
            printRDataInfo(rdata)
            # start is at sec 1
            rdata[c4d.RDATA_FRAMEFROM] = c4d.BaseTime(1)
            # end is at sec 2
            rdata[c4d.RDATA_FRAMETO] = c4d.BaseTime(2)
            rdata[c4d.RDATA_FRAMESTEP] = 1
            #just print again the values
            print "first change with values to secs"
            # start is at frame 5
            rdata[c4d.RDATA_FRAMEFROM] = c4d.BaseTime( 5.0, doc.GetFps())
            # end is at frame 15
            rdata[c4d.RDATA_FRAMETO] = c4d.BaseTime( 15.0,  doc.GetFps())
            print "second change with values to frames"
        Cheers, R
