    Rendering deformed Spline with Hair material
    c++
    19 Posts 2 Posters 6.7k Views 2 Watching
    • rsodreR Offline
      rsodre @r_gigante
      @r_gigante Yes, it's clear now. Thanks!
      rsodreR 1 Reply Last reply Reply Quote 0
      • rsodreR Offline
        rsodre @rsodre
        Hey @r_gigante ,
        Got back to this issue, I'm trying what I think is the fastest and easier path first, to create a new pure spline in the end of my modifier chain. But still no luck...
        I am sure the new spline is not being marked as dependence and is not being touched. Even though there's no deformers inside it, it has a deform cache. If I put the spline outside of my object, it will render, but I can still see it's got a deform cache. So maybe that's not the problem.
        The same does not happen for polygons, any polygon that I include inside the object or modifiers are rendered (of course, they are not touched), unlike the splines.
        Looks like the determinant factor to render the spline is the presence of OBJECT_INPUT on my generator (modifiers and end spline are inside it). Just removing this from the object register makes my spline render.
        What exactly is it doing to the children?
        Can I still create and use dependence lists if I remove it?
        • rsodreR Offline
          rsodre @r_gigante
          @r_gigante said in Rendering deformed Spline with Hair material:
          What is important to note is that in the end what is actually rendered is still an hair primitive and not the deformed spline.
          As additional note the hairs are not represented in the scene as real geometry that's why you can't find any evidence in the Active Object Dialog since the hair renderer is not handling with 3D data but delivers a representation of hair in 2.5D space where geometry is not needed.
          @r_gigante , when you say it draws in 2.5D space, do you mean the Hair Render post?
          At this moment, I'm interested in how to efficiently draw thousands of strands in the viewport. I suspect the LineStripBegin/End are not very efficient in this case. When Cinema 4D draws guides and hair in the viewport, does it use the same ObjectData::Draw() method we use?
          Can I use a VidePostData::GlDraw() to draw to the viewport instead?
          r_giganteR 1 Reply Last reply Reply Quote 0
          • r_giganteR Offline
            r_gigante @rsodre
            Hi Roger thanks for following up and happy new year!
            I'm going to punctually get back to you:
            @rsodre said in Rendering deformed Spline with Hair material:
            Exactly
            With regard to guides/hair, the hair library found in Cinema 4D indeed uses BaseDraw::LineStripBegin() / BaseDraw::LineStrip() / BaseDraw::LineStripEnd() methods to represent them in viewport.
            Not actually, if the strands are meant to appear in viewport.
            An example on how to use VideoPostData::GlDraw() is available here
            Best, Riccardo
            rsodreR 1 Reply Last reply Reply Quote 2
            • rsodreR Offline
              rsodre @r_gigante
              I find this odd, because the my performance is very poor compared to the native C4D hair, using the same amount of strands. Using the undocumented vertex buffers made my drawing operations up to 3 times faster. With that I have some new display issues, but I think is a different topic to discuss...
                r_gigante
                Hi Roger, thanks for your follow-up.
                In order to be of any further help, would you consider to show the part of your code where you're using the BaseDraw::Line* methods?
                With regard to
                I guess you're referring to use the VideoPostData::GlDraw(). Not being a static method how are you making use of it to display your strands in viewport? Am I missing something hereabout the context?
                Last but not least, please consider opening a new thread, since the discussion about strand representation in viewport is going to be off-topic.
                Best, Riccardo
                • rsodreR Offline
                  rsodre @r_gigante
                  @r_gigante I mean GlProgramFactory and GlVertexBuffer.
                  My issues are explained here.
                    r_gigante
                    Hi Roger, sorry for coming late here.
                    Unfortunately, with regard to the two highlighted classes, I can spend any further information rather than what's already included in c4d_gl.h
                    If there are no further question, I'd consider, and then mark, this thread as solved.
                    Best, Riccardo
                    • rsodreR Offline
                      rsodre @r_gigante
                      Hi Riccardo,
                      Since there's an open bug report regarding the main issue, shouldn't we keep it open until bug is investigated?
                      • rsodreR Offline
                        rsodre @r_gigante
                        While a deformed spline primitive like the Circle will not render, if I make it editable, turning it into an Ospline, it will finally render. Both have a line object in the deform cache, so I don't understand what object is being checked.
                        Hi Roger, you've totally tackled the issue, both their caches contain LineObject but not their generator: the first (the circle primitive) returns fail when checking IsInstanceOf(Oline) and on IsInstanceOf(Ospline) the other instead return true on IsInstanceOf(Ospline).
                        I'll let you know about the bug being fixed, but actually it's priority might be assessed as low.
                        Best, Riccardo
                        @r_gigante , any news about this?
                        The hair shader still can't render a deformed spline primitive/generator.
                        Do you have the bug number to track?
                          r_gigante
                          Hi @rsodre I'm sorry but I don't have any update on the bug resolution being it, as already stated, low-prio nor I can share bug-tracking information on a public forum.
                          Best, R
