    How is NBIT_CKEY_ACTIVE used?
    pythons22sdk
    3 Posts 2 Posters 309 Views 2 Watching
    • ? Offline
      A Former User
      How does one use NBIT_CKEY_ACTIVE? I see in the documentation that it's the "Active point of animation path in editor." I couldn't find any examples that use it successfully however. I found it used in this old post on CGSociety by Per-Anders from 2013, but I couldn't get it to work. Here's the code I'm using to test it:
          tracks = op.GetCTracks()
          for track in tracks:
              print "*"*100
              print track.GetName()
              curve = track.GetCurve()
              count = curve.GetKeyCount()
              for x in range(0,count):
                  key = curve.GetKey(x)
                  print "Key %s: NBIT_CKEY_ACTIVE: %s"%(x,key.GetNBit(c4d.NBIT_CKEY_ACTIVE))
      Thank you.
      • r_giganteR Offline
        r_gigante
        Hi @blastframe the NBIT_CKEY_ACTIVE is set when the animation path key is selected in the viewport (and not in the Timeline)
        Cheers, R
        • ? Offline
          A Former User @r_gigante
          @r_gigante Ahhhhhhhh, okay, I get it now. Thank you 😄
