    Descriptions: Animation
    SDK Help
    0
    • H
      On 14/08/2003 at 14:11, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      here is my _very_ last 😉 question about descriptions.
      In GetDDescription I add a parameter via
      BaseContainer bc = GetCustomDataTypeDefault(DTYPE_REAL);
      bc.SetBool(DESC_ANIMATE, DESC_ANIMATE_ON);
      bc.SetString(DESC_SHORT_NAME, "foobar");
      bc.SetReal(DESC_MIN, 3.0f);
      bc.SetReal(DESC_MAX, 15.0f);
      bc.SetReal(DESC_STEP, 1.0f);
      if(! description->SetParameter(DescLevel(15000, DTYPE_REAL, ID_OF_MY_PLUGIN), bc, DescLevel(ID_OF_MY_PARAM_GROUP)))
          return FALSE;
      return MaterialData::GetDDescription(node, description, flags);
      But the parameter cannot be animated: The animation pop-up menu opens on right mouse click, and "Add Keyframe" can be selected---but nothing happens: no red dot in front of the parameter name, no animation.
      Thanks for any ideas.
      Regards,
      jl
      • H
        On 14/08/2003 at 14:44, xxxxxxxx wrote:
        hmm, seems all correct. Shouldn´t make any difference but try to set bc.SetLong(DESC_ANIMATE, DESC_ANIMATE_ON); instead of SetBool (though this really shouldn´t matter. But hey, you´ll never know 😉
        Otherwise I don´t know to be honest.
        • H
          On 15/08/2003 at 01:21, xxxxxxxx wrote:
          I found out that my problem is elsewhere. If one sets a keyframe in the context menu, GetDDescription is called in such a way that bc == NULL in the following situation, although the parameter "is there":
          AutoAlloc<AtomArray> ar;
          if (!ar) return false;
          BaseContainer* bc = description->GetParameterI(DescLevel(FX_TECHNIQUE), ar);
          My code judged bc == NULL as an error condition.
          Regards,
          Jörn
