    Rotating Spline Points
    s22pythonsdk
    8 Posts 3 Posters 2.1k Views 1 Watching
    • ? Offline
      A Former User
      Hello!
      Does anyone know how to rotate all of the points of a spline in Python?
      • CairynC Offline
        Cairyn
        There is a long chapter on matrix operations in the docs:
        https://developers.maxon.net/docs/py/2023_2/manuals/data_algorithms/classic_api/matrix.html?highlight=rotation
        Build a matrix (for the correct reference system, center, and rotation axis) and multiply it with the points in question.
        Note: If you are using Bezier splines, there are tangents. These also need to be transformed, but keep in mind that tangents are vectors starting at the point, not at the object center.
        • CairynC Offline
          Cairyn
          Note that c4d.utils contains the most matrix building functions:
          c4d.utils.MatrixRotX(w)
          c4d.utils.MatrixRotY(w)
          c4d.utils.MatrixRotZ(w)
          c4d.utils.MatrixToRotAxis(m)
          c4d.utils.RotAxisToMatrix(v, w)
          etc.
          https://developers.maxon.net/docs/py/2023_2/modules/c4d.utils/index.html
          • ? Offline
            A Former User
            Hi @Cairyn,
            Thank you very much for the reply and for pointing me to the utils. I am familiar with the Matrix documentation, however, I'm not sure how to multiply the points & tangents of my Spline by the target Matrix and apply the result. I know how to get the vectors of the Point, Left Tangent, & Right Tangent, but what comes next?
                    pointCount = obj.GetPointCount()
                    interpolation = obj.GetInterpolationType()
                    if interpolation == c4d.SPLINETYPE_BEZIER:
                        for i in range(0,pointCount):
                            point = obj.GetPoint(i) #Point Vector
                            tangent = obj.GetTangent(i)
                            vl = tangent['vl'] #Left Tangent Vector
                            vr = tangent['vr'] #Right Tangent Vector
            Thank you.
            • CairynC Offline
              Cairyn
              You multiply all the points with the desired transformation matrix.
              For the tangents, you need to bring them into the transformation center before multiplying, and afterwards you bring them back to the point (note: the new position of the point).
              In short:
              from c4d import gui
                  pointCount = op.GetPointCount()
                  mat = c4d.utils.MatrixRotX(c4d.utils.DegToRad(45.0))
                      point = op.GetPoint(i) #Point Vector
                      tangent = op.GetTangent(i)
                      print point
                      vl = (vl - point) * mat
                      vr = (vr - point) * mat
                      point = point * mat
                      vl = vl + point
                      vr = vr + point
                      op.SetTangent(i, vl, vr)
                      op.SetPoint(i,point)
                  op.Message (c4d.MSG_UPDATE)
              (I removed all tests for object type etc so call this only on a proper bezier curve!)
              Here, I define the transformation matrix as rotation around X by 45 degrees.
              Then I go through the points (your code) and do the transformation for the point and its tangents as mentioned.
              The challenge may be to assemble the transformation matrix if you want a different rotation axis than X, Y, or Z... but you didn't mention what axis, so I stay with X 😊
              Learn more about Python on C4D:
              https://www.patreon.com/cairyn
              (Matrix transformations haven't been handled yet but will follow soon...)
              • ? Offline
                A Former User
                @Cairyn
                It works! 😄 This was VERY helpful, thank you!!!
                • N Offline
                  nophoto
                  You don't have to compensate the position of the tangent, if you use
                  c4d.Matrix.MulV(self, v)
                  to transform the direction vector.
                  from c4d import gui
                          point = point * mat
                          vl = mat.MulV(vl)
                          vr = mat.MulV(vr)
                  • ? Offline
                    A Former User @nophoto
                    @nophoto Very nice! Thank you 🏆
