    delete Redshift node
    3 Posts 2 Posters 981 Views 2 Watching
    • SwinnS Offline
      Swinn
      Is it possible to delete an Xpresso node using Python within a Redshift material? I am baking an object and when I move it to a new scene file, the user data parameters referenced inside the node are broken so I would like to remove the node.Screen Shot 2020-05-23 at 6.40.34 AM.png
      • r_giganteR Offline
        r_gigante
        Hi @Swinn, thanks for reaching out us.
        With regard to your question, once you've retrieved the root from the GvNodeMaster, you can traverse the shader graph and considering that a GvNode inherits from a BaseList2D and consequently from GeListNode you can delete it by calling GeListNode::Remove().
        Assuming this graph the code below deletes the noise node just by looking, for the sake of simplicity, at its name.
            activeMat = doc.GetActiveMaterial()
            if activeMat is not None and activeMat.GetType() != 1036224:
                print "Active material is not a RedShift one"
            outputNode = activeMat[c4d.REDSHIFT_GRAPH_NODES]
            if outputNode is None:
                print "Output node is not valid"
            gvMaster = outputNode.GetNodeMaster()
            if gvMaster is None:
                print "NodeMaster is not valid"
            gvRoot = gvMaster.GetRoot()
            if gvRoot is None:
                print "Root node is invalid"
            currentNode = gvRoot.GetDown()
            while currentNode is not None:
                if currentNode.GetName() = "RS Noise":
                    currentNode.Remove()
                    break
                currentNode = currentNode.GetNext()
            print "Node removed"
        Best, Riccardo
        • SwinnS Offline
          Swinn
          Cool! Thanks. 🙂
