SetChannel values...
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 09/08/2003 at 06:50, xxxxxxxx wrote: User Information:
 Cinema 4D Version: 8.100
 Platform: Windows ;
 Language(s) : C++ ;---------
 this code just won´t work. I cannot find any other way to set these values so this must be a bug. Please please please tell me I am wrong for I need it!! BaseChannel* ch = mat->GetChannel(CHANNEL_ALPHA); if(ch) { BaseContainer chbc = ch->GetData(); chbc.SetBool(1012,FALSE); //"Soft Alpha" Value ch->SetData(chbc); ch->Message(MSG_UPDATE); }Best
 Samir
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 09/08/2003 at 13:05, xxxxxxxx wrote: Have you tried GetParameter()?
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 09/08/2003 at 16:57, xxxxxxxx wrote: I have tried SetParamter and it doesn´t work :
 chbc.SetParameter(DescID(1012),GeData(0));
 ch->SetData(chbc);
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 16/08/2003 at 02:15, xxxxxxxx wrote: Maybe you overread it: Mikael wrote GETParameter... Cheers Kabe
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 16/08/2003 at 03:45, xxxxxxxx wrote: overread?  no, I WANT to overwrite it! I need to SET the channel. He just pointed at the function. The corresponding contrary would then be SetParameter that should actually solve the problem. But it doesn´t for it doesn´t work. no, I WANT to overwrite it! I need to SET the channel. He just pointed at the function. The corresponding contrary would then be SetParameter that should actually solve the problem. But it doesn´t for it doesn´t work.
