    Primitive Text Object
    3 Posts 0 Posters 299 Views
      On 27/07/2003 at 22:35, xxxxxxxx wrote:
      Cinema 4D Version:   7.303
      I want to change the text string value of a Primitive Text Object. I used the following code.
          if(vObj->GetPrimitiveType()==1017) // if TEXT Object
             var bc=vObj->GetContainer();
             bc->SetData(PRIM_TEXT_TEXT, "Change");
             vObj->SetContainer(bc);
          GeEventAdd(DOCUMENT_CHANGED);
          GeEventAdd(REDRAW_ALL);
      Even though I use GeEventAdd(), I cannot see the new text, still it shows the old text. But from the object manager when I check, it has changed the text with new one. What could be the problem?
        On 28/07/2003 at 06:00, xxxxxxxx wrote:
        did you try vObj->Message(MSG_UPDATE); ?
        I´m kind rusty concerning COFFEE but it should work 🙂
          On 28/07/2003 at 20:36, xxxxxxxx wrote:
          Yes, it works now.
          Thanks Samir.
