    Converting Pluginobject...
    8 Posts 0 Posters 789 Views
      On 27/07/2003 at 11:41, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      ---------Is there any way to determine whether the user is converting my pluginobject (generator)?
        On 08/08/2003 at 04:34, xxxxxxxx wrote:
        Any ideas anybody?
          On 08/08/2003 at 09:35, xxxxxxxx wrote:
          Probably not, but what do you mean by "converting" and where would you want to determine this?
            On 08/08/2003 at 09:39, xxxxxxxx wrote:
            converting = converting the object. When the user for example clicks "C". And as I said, need to determine it in my plugin object (Generator object).
            I want to prevent my object to create the geometry when the user tries to convert the object to a polygonobject.
            Any ideas?
            Thank you
              On 08/08/2003 at 12:13, xxxxxxxx wrote:
              I don't think this is possible. That "conversion" is really just C4D evaluating the object and putting the result back into the scene.
              Btw. if this is for a demo limitation then someone could just put your object inside a plugin object of his own and get the mesh that way. So once you let the geometry escape from GetVirtualObjects() it's public.
                yes, a demo was exactly my aim. Well, if it´s not safe...
                thank you!
                Best
                samir
                  On 08/08/2003 at 13:28, xxxxxxxx wrote:
                  Some alternatives are to put things in isoparams only or to replace part of the geometry by bounding box proxies.
                    On 08/08/2003 at 14:27, xxxxxxxx wrote:
                    Thanks for the suggestions Mikael. But I guess I´ll go the expiration way then 🙂
                    Best
                    Samir
