    Error in strings file documentation?
    4 Posts 2 Posters 775 Views 2 Watching
      heilei
      The documentation on this page:
      [https://developers.maxon.net/docs/cpp/2023_2/page_description_resource.html]
      ...defines the structure of a .str file like this:
      STRINGTABLE descriptionname
      NAME descriptionname;
      ELEMENT_1 "Long Name";
      ELEMENT_2 "Long Name" "Short Name";
      ...but all the examples I've seen so far look like this:
      descriptionname "some text here";
      Is there an error in the documentation or is this something that has changed in R21?
      • r_giganteR Offline
        r_gigante
        Thanks @heilei for reporting.
        It will be fixed in a future revision.
        Best, R
          heilei
          Ok, thanks for your reply. I think that particular help page should be rewritten completely, as there are many typographical problems regarding reserved words vs. placeholders. F.ex. words like "CONTAINER", "STRINGTABLE" and "INCLUDE" are meant to be reserved words (i.e. they should appear as-is in the .res or .str file). On the other hand, "ELEMENTTYPE" is not a reserved word (if I've understood the syntax correctly); it represents any valid attribute type, f.ex. "BOOL". There might be other examples as well.
          This is probably all clear to experienced C4D developers, but for a newcomer such as myself, the documentation is somewhat confusing. Typography really matters, when you're defining a syntax to someone new.
            r_gigante
            Hi @heilei thanks again for the comment! We'll try, where meaningful, to improve the typography in future releases.
            Best, R
