    detect the selection of an object
    13 Posts 4 Posters 4.2k Views 2 Watching
      mp5gosu
      That's a PickSession Candidate, right?
      • Passion3DP Offline
        Passion3D
        PickSession?
          mp5gosu
          A PickSession() lets you retrieve objects. The transfer tool uses something similar.
          Although, it may not be possible to directly click in the object tree with a tool enabled (and there are no tools in C4D that I know of), but you could add a link to your tool that allows you to pick an object that should be considered for placing.
          Take a look at the transfer tool - maybe that's what you're looking for.
            Passion3D
            It's from R19 only. It will remove OnFloor compatibility from R13 to R18 😞
            • C4DSC Offline
              C4DS
              I have been in need of something similar as well. And if I remember correctly it has been discussed a few years ago.
              Reason is that a ToolData or DescriptionToolData might need to initialize some stuff depending the currently active object. When the user selects a different object in the ObjectManager, the ToolData might need to reinitialize some stuff.
              The solution proposed in the past was to use a MessageData and listen to EVMSG_CHANGE to check if a different object has been selected using the object's "unique" id and then trigger the ToolData by sending a SpecialEvent ... or something.
              It is quite a complex implementation that seems to work, but probably is very error prone.
              I wish we would have had some kind of message telling the active object selection was changed (from inside the ToolData), not via-via. And definitely not using such a hacky and complex solution.
              It has been a while, but I seem to remember that the whole use of the object's unique id was rather flawed as the id didn't exactly seem to be that unique after all.
              Anyway, I am still hoping for a nice solution to detect when user changes the current active object. But it seems to not be possible after all.
                mp5gosu @Passion3D
                @passion3d said in detect the selection of an object:
                If I'm not mistaken, in prior versions it must have been ViewportSelect.PickObject().
                C4DS approach sounds a bit more elegant, yet hacky and thus probably error-prone. I'd go for the more robust solution. Even if that means a lack in comfort.
                  Passion3D
                  ViewportSelect.PickObject(), this is what I use to select an object in the 3D View.
                  What I'm trying to do seems complex and unreliable.
                  I'll try to find another solution.
                  As I said, when the scene is complex, it is difficult to reach a particular object, especially if it is small.
                    mp5gosu
                    Then, why don't you simply add a LinkListGui or a Link field? I had a similar plugin written, which allows me to build a list for snapping candidates. That works pretty well.
                    • C4DSC Offline
                      C4DS
                      @Passion3D
                      As this topic seems to be "solved" could the solution be provided, or discussed. It might be helpful to others. And I am definitely interested to hearing a solution in more details.
                        Passion3D
                        @C4DS
                        Although a solution has not been given (as I wish to do), explanations have been provided. I have therefore considered it resolved.
                        For IRL reasons, I could not do so. I will be able to get back to it, and if I find THE solution, I will post it 😉
