    Drag and Drop Messages
    SDK Help
    0
    • H
      On 24/07/2003 at 03:45, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hiya
      I have searched the forum and used the same exact code that I have found, yet it doesn't work.
      the code I looked at says to do this..
          oDialog::Message(msg)
           if(msg->GetId() == BFM_DRAGRECEIVE)
      but console quickly gets filled up with member not found errors on the if statement. It seems the msg doesn't have a GetID() member.
      The COFFEE SDK on the other hand says to do something like this
            if (msg->GetData(BFM_DRAG_FINISHED))
                  if (CheckDropArea(DRAG_TEST, msg))
                    var obj = GetDragObject(msg);
                    var result = new(BaseContainer, BFM_DRAGRESULT);
                    result->SetData(BFM_DRAGRESULT_CURSOR, MOUSE_POINT_HAND);
                    return result;
            return super::Message(msg);
      but that errors on line var result = new(BaseContainer, BFM_DRAGRESULT); with 'Variable or Function expected'
      What am i doing wrong? which way is correct?
      • H
        On 24/07/2003 at 06:05, xxxxxxxx wrote:
        Where are you calling this from? I won´t run my code a fourth time here so please do search the forum once again. There is a working code available.
        Best
        Samir
        • H
          On 24/07/2003 at 14:45, xxxxxxxx wrote:
          Thanks, i didnt see your complete drag plugin code on my previous search. Just tried it and it worked. Thanks
          Still don't see what I did wrong though, but i will disect it to work it out
          • H
            Also if it sounds arrogant but that´s a good exercise to get into COFFEE. Without obstacles or problems, it would take longer to learn it than without them.
            • H
              On 25/07/2003 at 11:22, xxxxxxxx wrote:
              And please report your results... 🙂
              • H
                On 25/07/2003 at 16:22, xxxxxxxx wrote:
                I found out what it was. It was a silly amatuer mistake. Wrong case-sensitivity
                My code was
                      if(msg->GetID() == BFM_DRAGRECEIVE)
                ->GetID() should have been ->GetId()
                silly me
