    Polygon Points Manipulating
    4 Posts 0 Posters 498 Views
      On 20/07/2003 at 11:06, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hi all
      I am trying to get the point information from each polygon in my object how can i do this? the SDK is pretty limited to explaining how?
      I use the Obj->GetPolygons(); to list the individual points in the objects but i need to access the points of individual polys and determine if they are tri or quad?
      by the way i am using Cinema 4d Xl 6.3 not 8.1 as the silly post says!
      thanks
      Manwich
        On 21/07/2003 at 16:03, xxxxxxxx wrote:
        1. The SDK seems to provide all needed information for your question:
            class Polygon
        Polygon();
        _<_h2_>_Descrip_<_h2_>_/H2>
        A Polygon structure.
        _7>
        _<_h2_>_nation
        The variables
            a
            b
            c
        and
            d
        refer to point indexes. Triangles are defined by making
            d
        the same as
            c
        by the way, you have posted this "silly" post and that you are using 8.100 😉
        Best
        Samir
          On 23/07/2003 at 10:52, xxxxxxxx wrote:
          Oh yeah i just realised about the polygon class!
          dont suppose any body got any examples of using this class?
          by the way when i registered it never asked my version of cinema seems it assumed i was using 8.1.
          thanks
          Manwich
            have a look on my website in the COFFEE area, there is a library with several useful functions. There is also a little function that calculates the midpoint of a polygon. You can see how it is used in there. www.3ddesigner.net
            >by the way when i registered it never asked my version of cinema seems it >assumed i was using 8.1.
            You need to set this whenever you make a new thread 😉
            Best
            Samir
