    Material Link
    4 Posts 0 Posters 517 Views
      On 16/07/2003 at 04:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I am trying to read the LINK from TextureTag, but I always get a
      NULL - Pointer . The other datas from TextureTag could I read.
      Here is some part of my code:
      void explore_tag(BaseObject *base)
       BaseContainer bc;
       BaseMaterial *bmat = NULL;
       BaseList2D  *bl = NULL;
       BaseTag   *tag = base->GetFirstTag();
       BaseDocument *doc = GetActiveDocument();
      for (; tag!=NULL; tag = tag->GetNext())
        GePrint("    TAGS: "+tag->GetName());
        bc = tag->GetData();
        //  bl = bc.GetLink(TEXTURETAG_MATERIAL,doc);
        //bmat = bc.GetMaterialLink(TEXTURETAG_MATERIAL,doc);
      if (bmat) GePrint("BaseMaterial vorhanden");
        Real x = bc.GetReal(TEXTURETAG_LENGTHX);
        Real y = bc.GetReal(TEXTURETAG_LENGTHY);
        GePrint("X: "+RTS(x)+"  Y: "+RTS(y));
        LONG mapping = bc.GetLong(TEXTURETAG_PROJECTION);
        String res = bc.GetString(TEXTURETAG_RESTRICTION);
        GePrint("Restriction:  "+res);
        switch (mapping)
        case (0) : GePrint("Kugel-Mapping");break;
        case (1) : GePrint("Zylinder-Mapping");break;
        case (2) : GePrint("Fläche-Mapping");break;
        case (3) : GePrint("Quader-Mapping");break;
        case (4) : GePrint("Frontal-Mapping");break;
        case (5) : GePrint("Spat-Mapping");break;
        case (6) : GePrint("UVW-Mapping");break;
        case (7) : GePrint("Shrink-Mapping");break;
      Where is the problem or error ??
        On 02/03/2007 at 04:21, xxxxxxxx wrote:
        *bump*
        same problem here. didnt want to start a new topic.
        BaseTag *baset = obj->GetTag(Ttexture,0);
        BaseContainer basec = baset->GetData();
        BaseMaterial *bm = basec.GetMaterialLink(TEXTURETAG_MATERIAL, doc);
        always returns a null-pointer. could use some help
          On 02/03/2007 at 11:49, xxxxxxxx wrote:
          Try this instead:
          GeData data;
          ttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL);
          Material* mat = static_cast<Material*>(data.GetLink(doc, Mbase));
          if (!mat) return FALSE;
            On 03/03/2007 at 04:03, xxxxxxxx wrote:
            thank you. works very well.
