    VolumeObject ReadObject and WriteObject no supported?
    c++r20
    3 Posts 2 Posters 557 Views 1 Watching
    • kbarK Offline
      kbar
      I am manually saving objects within my own Generator. It seems that if I write out, then read a VolumeObject that it does not save any volume data at all. Calling GetVolume() returns nullptr; My volumes do have data in them so I would expect it to save and load.
      pObj = VolumeObject::Alloc();
      pObj->ReadObject(hf, true);
      maxon::VolumeInterface* data = pObj->GetVolume();
      data is null;
      Can someone confirm if this is actually true and the correct behaviour?
      https://www.plugins4d.com
      • r_giganteR Offline
        r_gigante
        Hi Kent, thanks for reaching out us.
        With regard to your issue, at the moment writing/reading a VolumeObject using the C4DAtom::WriteObject / C4DAtom::ReadObject using an Hyperfile is not supported if the HyperFile object operates on disk.
        At the moment a workaround is represented by using a temporary memory file, write into that, write that to disk. To read/write using MemoryFileStruct please visit here.
        The following code shows how to read/write VolumeObject from/to memory-located HF.
        	iferr_scope;
        	// alloc the VolumeObject to write
        	AutoAlloc<VolumeObject> volObjWrite;
        	if (!volObjWrite)
        		return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
        	// put some data in the VolumeObject
        	const maxon::Int    gridIndex = 0;
        	const maxon::Url volumeUrl ("<your path to a vdb>"_s);
        	const maxon::Volume volume = maxon::VolumeInterface::CreateFromFile(volumeUrl, 1.0, gridIndex) iferr_return;
        	// insert volume
        	volObjWrite->SetVolume(volume);
        	// alloc HF
        	AutoAlloc<HyperFile> hf;
        	if (!hf)
        	// alloc MemoryFileStruct
        	AutoAlloc<MemoryFileStruct> mfs;
        	if (!mfs)
        	// alloc Filename and set to memory
        	Filename fn;
        	fn.SetMemoryWriteMode(mfs);
        	// open HyperFile to write
        	if (!hf->Open(0, fn, FILEOPEN::WRITE, FILEDIALOG::NONE))
        		return maxon::UnknownError(MAXON_SOURCE_LOCATION);
        	// write volume to memory HF
          Bool writeRes = volObjWrite->WriteObject(hf);
        	if (writeRes)
        		DiagnosticOutput("volume written on HF");
        	// close written HF
        	hf->Close();
                //... write memory-located HF to disk
                //... do your stuff
                //...read from disk the memory-located HF
        	// open HF to read
        	if (!hf->Open(0, fn, FILEOPEN::READ, FILEDIALOG::NONE))
        	// alloc the VolumeObject to read
        	AutoAlloc<VolumeObject> volObjRead;
        	if (!volObjRead)
        	// read volume from memory HF
        	Bool readRes = volObjRead->ReadObject(hf, true);
        	const maxon::VolumeInterface* volRead = volObjRead->GetVolume();
        	if (readRes && volRead)
        		DiagnosticOutput("volume read from HF");
        	hf->Close();
        	return maxon::OK;
        Best, Riccardo
        • kbarK Offline
          kbar
          Thanks Riccardo.
