    COF dialog woes...
    4 Posts 0 Posters 542 Views
      On 16/06/2003 at 13:10, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Mmmh, it starts to get a little frustrating here...
      The dialog opens up correctly, but no value is set.
      What's wrong here? Any ideas?
           //create dialog
           if (!gDial) gDial=new(mDialog);
           //initialize
           gDial->SetFloat(IDC_LIMIT_R,3.0,0.0,10000.0,1.0);
           gDial->SetFloat(IDC_LIMIT_G, settings->GetFloat(1),0.0,10000.0,1.0);
           gDial->SetFloat(IDC_LIMIT_B, settings->GetFloat(2),0.0,10000.0,1.0);
           t1=settings->GetFloat(3);
           t2=settings->GetFloat(4);
           t3=settings->GetFloat(5);
           temp=vector(t1,t2,t3);
           gDial->SetColorChooser(IDC_COLOR1, temp, 1.0, 1.0, NO_BRIGHTNESS);
           //... and open
           gDial->Open(TRUE,-1,-1);
      While I'm at it: How can I access the settings container from the dialog? I would like to update the settings when the values were changed in the dialog of course.
      Kabe
        On 16/06/2003 at 15:33, xxxxxxxx wrote:
        ? You should initialize the values in the overloaded dialog methods like Init.
          On 17/06/2003 at 04:42, xxxxxxxx wrote:
          Yep, I realized that in the meantime.
          To sum it up for later reference:
          Add the neccessary variables to the dialog class.
          Use these variables in mDialog::Init() to set the dialog controls, as Init() is called right before the dialog is actually opened.
          Considering this I think that the dialog methods for setting interface elements shouldn't be public anyway....
          Thanks!
          Kabe
            On 17/06/2003 at 04:45, xxxxxxxx wrote:
            ... and do not access settings from the dialog box either. Set the local variables of mDialog instead.
            Kabe
