    Reorder gradient knots by position
    c++sdk
    3 Posts 2 Posters 526 Views 1 Watching
    • mfersaouiM Offline
      mfersaoui
      I'm searching a method to get gradient Knot by position not by index, the problem with gradient->GetKnot(i) is that when user change the knots position and knots order, the knot index stay the same for each knot.
      I had create the following python function to get knot by position and I sorted them from lower to higher knot position.
      def GetKnotByPos(gradient, index):
          KnotDict = {}
          knotCount = gradient.GetKnotCount()
          for i in range(knotCount) :
              KnotDict[gradient.GetKnot(i)['pos']] = gradient.GetKnot(i)
          # dictionary’s keys select.
          Ks = list(KnotDict.keys())
          Ks.sort()
          return KnotDict[Ks[index]]['col']
      # Use
      gradient = op[c4d.MYOBJECT_GRADIENT]
      for index in range(gradient.GetKnotCount()):
          color = GetKnotByPos(gradient, index)
      I'm searching how to do the same thing but using c++.
      const Int32 knotCount = gradient->GetKnotCount();
      for (Int32 i = 0; i < knotCount; i++)
      	GradientKnot knot = gradient->GetKnot(i);
      	const Vector color = knot.col;
      	result += String::VectorToString(color) + "\n";
      • S Offline
        s_bach
        you can use a maxon::BaseArray to store elements in a list. You can use maxon::BaseSort to define a class that is able to sort the elements of such a BaseArray.
        In the case of GradientKnots, it could look like this:
        // custom BaseSort based class
        class GradientSort : public maxon::BaseSort<GradientSort, maxon::BASESORTFLAGS::NONE>
          static inline Bool LessThan(GradientKnot a, GradientKnot b)
            return a.pos < b.pos;
        // prepare array
        maxon::BaseArray<GradientKnot> knots;
        knots.EnsureCapacity(knotCount) iferr_return;
        // fill array
          knots.Append(knot) iferr_return;
        // sort the elements stored in the array
        GradientSort sort;
        sort.Sort(knots);
        // check order
        for (GradientKnot& knot : knots)
          DiagnosticOutput("Pos: @", knot.pos);
        mfersaouiM 1 Reply Last reply Reply Quote 2
          mfersaoui @s_bach
          @s_bach
          Hi Sebastian,
          Perfect, thank you very much.
          Best regards,
          Mustapha
