    STRINGENCODING -> StringEncodingRef ?
    classic apic++r21
    3 Posts 2 Posters 518 Views 1 Watching
    • fwilleke80F Offline
      fwilleke80
      Hi all,
      as we are managing loads of code that needs to stay backwards compatible with several releases, I came across the changes in String::GetCString() resp. maxon::StringInterface::GetCString(). The first accepts an argument of type STRINGENCODING to specify the desired encoding. The second one accepts a StringEncodingRef&.
      Is there some handy function which I can pass a STRINGENCODING value and get the corresponding StringEncodingRef in return? I can write myself with no problem, just wanted to know if there's something in the API already.
      Frank
      www.frankwilleke.de
      • r_giganteR Offline
        r_gigante
        Hi Frank,
        at the current time, we don't have any publicly-exposed method to achieve this. Some methods are available internally and I should check if they can safely exposed. Although I'll keep you updated on the topic, for the time being I consider it closed.
        Best, Riccardo
          r_gigante
          Hi Frank, I've just been confirmed that the function will be exposed in the future.
          Best, Riccardo
