    How to get the JSON parser to work?
    r21c++
    5 Posts 2 Posters 1.1k Views 1 Watching
    • fwilleke80F Offline
      fwilleke80
      I'm trying to parse some JSON data here. The code so far is simple enough...
      const maxon::JsonParserRef jsonParser = maxon::JsonParserRef::Create() iferr_ignore();
      maxon::DataDictionary responseData;
      jsonParser.Read(response.body, maxon::JSONPARSERFLAGS::NONE, responseData) iferr_ignore();
      Compiling in Xcode 10.1 bring up the error:
      Showing Recent Issues
      /Applications/MAXON/Cinema 4D R21/frameworks/core.framework/source/maxon/delegate.h:792:10: Type 'maxon::DataDictionary' does not provide a call operator
      Commenting out the last line of the example code lets the error disappear.
      How does this work?
      Thanks & greetings from Berlin,
      Frank
      PS: Some example code, especially for the newer stuff in die API would be fantastic 😉
      PPS: The complete error output:
      In file included from /Applications/MAXON/Cinema 4D R21/plugins/myPlugin/source/some_sourcefile.cpp:9:
      In file included from ../../frameworks/cinema.framework/source/c4d.h:14:
      In file included from ../../frameworks/cinema.framework/source/c4d_basebitmap.h:13:
      In file included from ../../frameworks/cinema.framework/source/ge_math.h:120:
      In file included from ../../frameworks/core.framework/source/maxon/vector.h:5:
      In file included from ../../frameworks/core.framework/source/maxon/string.h:4:
      In file included from ../../frameworks/core.framework/source/maxon/interfacebase.h:6:
      In file included from ../../frameworks/core.framework/source/maxon/datatypebase.h:4:
      In file included from ../../frameworks/core.framework/source/maxon/collection.h:5:
      ../../frameworks/core.framework/source/maxon/delegate.h:792:10: error: type 'maxon::DataDictionary' does not provide a call operator
      return (*static_cast<T*>(objectPtr))(std::forward<ARGS>(args)...);
      ../../frameworks/core.framework/source/maxon/delegate.h:760:49: note: in instantiation of function template specialization 'maxon::Delegate<maxon::Result<bool> (const maxon::DataDictionary &)>::FunctorStub<maxon::DataDictionary>' requested here
      new (this) DelegateBase(std::forward<FN>(fn), FunctorStub<FunctorType>, UtilityStub<FunctorType>);
      ../../frameworks/core.framework/source/maxon/delegate.h:407:3: note: in instantiation of function template specialization 'maxon::Delegate<maxon::Result<bool> (const maxon::DataDictionary &)>::ConstructFrom<maxon::DataDictionary &>' requested here
      ConstructFrom(std::forward<FN>(fn));
      /Applications/MAXON/Cinema 4D R21/plugins/myPlugin/source/some_sourcefile.cpp:617:66: note: in instantiation of function template specialization 'maxon::Delegate<maxon::Result<bool> (const maxon::DataDictionary &)>::Delegate<maxon::DataDictionary &, void>' requested here
      www.frankwilleke.de
      • r_giganteR Offline
        r_gigante
        Hi Frank, thanks for reaching out us.
        With regard to the JSON parser, I've used its implementation in the examples showing how the new licensing system can work with 3rd party plugins.
        There's a bunch of code in on our Github repo:
        • writing JSON is here;
        • reading JSON is here.
        Hope both snippets could serve the scope.
        Greeting from Italy!
        Riccardo
          fwilleke80
          Cool, hadn't seen that one yet. Thanks!
          www.frankwilleke.de
            fwilleke80
            A little follow-up question, as I don't really understand it from the provided example code:
            How would I read nested values from a JSON? For example:
                "some_object" : {
                    "some_data": {
                         "title": "foo"
            How would I read json["some_object"]["some_data"]["title"] ?
            Thanks in advance!
            Frank
            www.frankwilleke.de
              r_gigante
              Hi Frank,
              actually you can deal with by checking the type of the stored value and read it as a maxon::DataDictionary
              	if (value.GetType() == maxon::GetDataType<maxon::DataDictionary>())
              		nestedDataDict = value.Get<maxon::DataDictionary>() iferr_return;
              Hope this helps.
              Riccardo
