    Access violation in MkVarTag
    4 Posts 0 Posters 1.3k Views
      On 12/06/2003 at 20:04, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      op = PolygonObject::Alloc(vcount,fcount); (998,1515)
      if(!op) return 0;
      uvtag = (UVWTag* )op->MakeVariableTag(vtcount); (998)
      if(!uvtag) return 0;
      The forth time I create an object I get a 'unhandled exception in Cinema4D.exe Access Violation' error in the MakeVariableTag call. I'm only creating one UVtag per object at this point.
      What would prevent me from making a call with a valid PolygonObject? I would expect it would at worst return null.
      I'm having a similar problem with the ResizeObject. When I resize the third object I get the same error and then the Access error on trying to make the UV tag on the fourth if I comment out the resize call.
      I have 1.5 G memory on this box now.
      What would cause these types of problems (not at all assuming it's the app code and not me)?
      David
        On 13/06/2003 at 13:12, xxxxxxxx wrote:
        MakeVariableTag(vtcount) works like that?? Shouldn´t the compiler cry?
        Have you tried this: (UVWTag* )op->MakeVariableTag(Tuvw,vtcount,NULL);
        You aren´t specifying the type of tag at all...weird that your compiler compiles this, mine doesn´t...
        I don´t know though if this is the problem.
          On 13/06/2003 at 13:35, xxxxxxxx wrote:
          Sorry - typo
          the call I make is
          (UVWTag* )op->MakeVariableTag(Tuvw,vtcount);
          the last value defaults.
          (No email on my work PC)
          david
            On 13/06/2003 at 13:36, xxxxxxxx wrote:
            Are you freeing your the polygonobject at the end? Have you tried to do some debug sessions to find out where exactly it crashes?
