    Linearize an exponential function
    c++sdk
    4 Posts 2 Posters 592 Views 2 Watching
    • mfersaouiM Offline
      mfersaoui
      I have created an user data slider (with percent unit) to controlling subdivisions number of a spline (spline with an Adaptive interpolation). So I have used a MapRange function to convert a percentage to a degree but this dosen't returnning a natural result. because the number of an intermediate subdivision points is increasing exponentially.
      I want to know how to fit an exponential number of intermediate points to a linear.
              SplineObject *sp = SplineObject::Alloc(4, SPLINETYPE_BEZIER); // create a spline with 3 verts
              Vector *gp = sp->GetPointW();
              gp[0] = Vector(0, 0, 0);
              gp[1] = Vector(0, 0, 900);
              gp[2] = Vector(0, 250, 1200);
              gp[3] = Vector(0, 900, 1200);
              sp->GetDataInstance()->SetBool(SPLINEOBJECT_CLOSED, false);
              Float value = data->GetFloat(BSK_OBJECT_CURVE_SUB);
      	Float min_input = 0;
      	Float max_input = 1;
      	Float min_output = 90;
      	Float max_output = 1;
      	Float inrange = max_input - min_input;
      	if (CompareFloatTolerant(inrange, 0.0)) value = 0.0;
      	else value = (value - min_input) / inrange;
      	curve_sub = DegToRad(min_output + (max_output - min_output) * value);
      	sp->SetParameter(SPLINEOBJECT_ANGLE, curve_sub, DESCFLAGS_SET_0);
      • r_giganteR Offline
        r_gigante
        Hi mfersaoui, thanks for reaching out us.
        With regard to your issue I've a few notes:
        • the Adaptive interpolation is by definition strictly dependent on the shape of the spline with regard to the tessellation of the curve: the curve will be tessellated more where the curvature is larger and this generates evidently non-uniform segments distribution - check here for further notes -;
        • standing on the code presented the in_range variable is always 1.0 which makes this
        pretty useless.
        I would recommend, assuming that the adaptive strategy is the one you want to keep to consider ( sorry for the python code, but porting should be trivial)
                # swap the max/min values of the slider
                val = op[c4d.ID_USERDATA, 1]
                # set the interpolation method
                interp = 3
                # allocate the spline
                spline = c4d.SplineObject(4, c4d.SPLINETYPE_BSPLINE)
                # set interpolation method
                spline[c4d.SPLINEOBJECT_INTERPOLATION] = interp
                # switch according to interpolation method
                if interp == 2: # uniform
                    # set the max number of segs
                    maxSegs = 100
                    spline[c4d.SPLINEOBJECT_SUB] = int(maxSegs * val)
                if interp == 3: # adaptive
                    # get the rad representation of the slider's value
                    radVal = c4d.utils.DegToRad(90 * (1.0 - val))
                    # set the adaptive angle value
                    spline[c4d.SPLINEOBJECT_ANGLE] = radVal
                # set the points
                point = spline.SetAllPoints((c4d.Vector(0,0,0),c4d.Vector(0,0,900),c4d.Vector(0,900,900), c4d.Vector(0,900,0)))
                # return the spline
                return spline
        If instead you'd like to linearly increase the subdivision, I warmly recommend to switch to the uniform method and you'll see that a linear behavior is established
        Best, R
        mfersaouiM 2 Replies Last reply Reply Quote 1
          mfersaoui @r_gigante
          @r_gigante Thank you for the detailed reply,
          Sorry, I didn't put the last part of my code in my question above. I will mention that I want to set a tangent on the points 2 and 3, here is the last part of my code in python:
          curve_offset = op[c4d.BSK_OBJ_CURVE_OFFSET] # correspond to the value "250" in my above code
          spline.SetTangent(1, Vector(0, 0, 0), Vector(0, 0, curve_offset * 0.5))
          spline.SetTangent(2, Vector(0, -curve_offset * 0.5, 0), Vector(0, 0, 0))
          So, I try to add the lines above on your code but this returning this error message:
          IndexError: tangent index out of range
          Thanks Again.
            @r_gigante
            Finally I found the solution to linearize the subdivision expansion on Adaptive spline interpolation on the angle deviation.
            I just replaced the line :
            By :
            radVal = math.pow(val, -0.85)
            I changed also the slider user data unit to REAL
            if I want to keep it with a PERCENT unit I just multiply the value by 100
            radVal = math.pow(val*100, -0.85)
            Here is demo:
