    Get/Fetch Node from an Existing Xpresso Tag
    r20python
    3 Posts 2 Posters 1.2k Views 1 Watching
    • B Offline
      bentraje
      Is there a way to get/fetch a node from an existing xpresso tag? For instance, of all 5 existing math nodes, select a node with a particular name or a particular operation type (i.e. multiply as opposed to add).
      In the documentation there is GetNode method but it is specific to port. Basically, what I am after is something like.
      obj = doc.SearchObject("obj")
      tag = obj.GetTag(c4d.Texpresso)
      nodemaster = tag.GetNodeMaster()
      # get/fetch a particular node  in  the list of nodes of nodemaster
      Is this possible? Thank you for looking at my problem.
        Hi @bentraje GvNode are standard BaseList2 that means you can iterate them as you can iterate object in the ObjectManager.
        With that's said here is an example:
        Copyright: MAXON Computer GmbH
        Author: Maxime Adam
        Description:
            - Loops through all nodes from the Xpresso Tag of the selected object.
            - Checks if it's a Math Node.
        Class/method highlighted:
            - c4d.modules.graphview.GvNodeMaster
            - GvNodeMaster.GetRoot()
            - GvNode.GetNext() / GvNode.GetUp() / GvNode.GetDown()
            - GvNode.GetOperatorID()
        Compatible:
            - Win / Mac
            - R13, R14, R15, R16, R17, R18, R19, R20
        def iterateNodes(node):
            This function iterates over a BaseList2D, GvNode inherit from BaseList2D.
            :param node: GvNode to iterate.
            while node:
                nodeName = node.GetName()
                isMathNode = node.GetOperatorID() == c4d.ID_OPERATOR_MATH
                # If it's a math node and set to multiply, prints the node name
                if isMathNode:
                    isMultiply = node[c4d.GV_MATH_FUNCTION_ID] == c4d.GV_MUL_NODE_FUNCTION
                    if isMultiply:
                        print "Name: {0}".format(node.GetName())
                # If it's a group retrieves all inner GvNode.
                if node.IsGroupNode():
                    iterateNodes(node.GetDown())
                node = node.GetNext()
            # Checks if selected object is valid
            if op is None:
                raise ValueError("op is none, please select one object.")
            # Retrieves the xpresso Tag
            xpressoTag = op.GetTag(c4d.Texpresso)
            if xpressoTag is None:
                raise ValueError("Make sure the selected object get an Xpresso Tag.")
            # Retrieves the node master
            gvNodeMaster = xpressoTag.GetNodeMaster()
            if gvNodeMaster is None:
                raise RuntimeError("Failed to retrieves the Node Master.")
            # Retrieves the Root node (the Main XGroup) that holds all others nodes
            gvRoot = gvNodeMaster.GetRoot()
            if gvRoot is None:
                raise RuntimeError("Failed to retrieves the Root Node.")
            # Iterates overs all nodes of this root node.
            iterateNodes(gvRoot)
        • B Offline
          bentraje
          Thanks @m_adam. Works as expected.
          My bad, I was looking at the documentation hierarchy erroneously (i.e c4d > modules > graphview > GvNode)
          Just a note: I think the if Multiply: line is supposed to be if isMultiply:.
          Thanks again. Have a great day ahead!
