    HashMap with BaseArray as value
    r19c++
    3 Posts 2 Posters 547 Views 2 Watching
    • C4DSC Offline
      C4DS
      With R20 I had no problem using a HashMap with a BaseArray<Int32> as value. All compiling fine, and working as expected.
      Porting that implementation to R19 (for users having not upgraded to R20), I encounter a compiler error, mentioning that the operator= cannot be accessed, since private.
      Obviously, I had to replace the R20 HashMap::Insert for an R19 HashMap::Put and there seems to lie the problem
      	// key is an integer and value an array of integers
      	maxon::HashMap<Int32, maxon::BaseArray<Int32>> dataKeyValue;
      	const Int32 key = 1;
      	maxon::HashMap<Int32, maxon::BaseArray<Int32>>::Entry* e = dataKeyValue.FindEntry(key);
      	if (e)
      		maxon::BaseArray<Int32>& values = e->GetValue();
      	else
      		maxon::BaseArray<Int32> newValues;
      		dataKeyValue.Put(key, newValues);
      The compiler error:
      error C2248: 'maxon::BaseArray<Bool,16,maxon::BASEARRAYFLAGS_0,maxon::DefaultAllocator>::operator =': cannot access private member declared in class 'maxon::BaseArray<Bool,16,maxon::BASEARRAYFLAGS_0,maxon::DefaultAllocator>'
      Any hint what I could do in order to have the same functionality compiled in R19?
      Thanks in advance.
      • r_giganteR Offline
        r_gigante
        Hi Daniel, thanks for reaching out us.
        With regard to your question, the old HashMap::Put implementation does only support types which have a copy-assignment operator. But there’s the FindOrCreateEntry function which inserts an entry and default-initializes the value, then the value can be set later.
        maxon::Bool created = false;
        maxon::HashMap<Int32, maxon::BaseArray<Int32>>::Entry* e = dataKeyValue.FindOrCreateEntry(key, created);
        if (!e)
                // error handling
        if (created)
                e->SetValue(std::move(newValues));
        Let me know if it does work as expected.
        Cheers, Riccardo
        C4DSC 1 Reply Last reply Reply Quote 1
        • C4DSC Offline
          C4DS @r_gigante
          @r_gigante
          Thanks for the headsup about FindOrCreateEntry.
          Since Put does use that method internally, I didn't even consider about trying to use it, as I simply assumed it would have the same issue. Guess I was wrong about not trying it.
          Problem solved.
