    Accessing Octane node editor with python
    r20
    5 Posts 3 Posters 3.2k Views 1 Watching
    • S Offline
      sheilan
      I know Octane isnt related to Maxon devs, but perhaps someone knows how to do that.
      Ive creates new octane material and assigned image textures, but unfortunately thats not enough. I need to access the node editor to modify those images using the nodes, but I cant seem to find anything about Octane + Python.
      Sheilan.
      • G Offline
        Graeme
        Not about the node editor specifically, but there are some example Python Octane scripts in this thread:
        https://render.otoy.com/forum/viewtopic.php?f=30&t=43086&p=208809&hilit=python#p208809
        Also, here is a script I wrote to convert Octane Materials to native Cinema 4D ones, mainly so the textures are picked up by FBX export to Unreal. It shows you examples of some of the Octane nodes etc. It's a little crude, but every line is commented. When it comes to finding out the ID's for different Octane nodes, you can drag them into the console & then add '.GetType()' & hit enter - that will give you the numerical ID for that Octane node.
        OctaneToC4d
        v0.1
        Written by Graeme McDougall for Painting Practice
        Copyright: Painting Practice (www.paintingpractice.com)
        Written for Cinema 4d R20.057
        Name-US:OctaneToC4d
        Description-US:Converts selected Octane materials to Cinema 4d materials, as best as possible
        from c4d import documents
        ID_OCTANE_MATERIAL = 1029501                                                      #Here we define more readable IDs for any integer IDs we are using
        ID_OCTANE_IMAGE_TEXTURE = 1029508                                                 #To make our code more readable
        ID_OCTANE_COLORCORRECTION = 1029512
        ID_OCTANE_INVERT_TEXTURE = 1029514
        ID_OCTANE_MULTIPLY_TEXTURE = 1029516
        ID_OCTANE_MIXTEXTURE = 1029505
        mainLayerId = 526336
        def CheckSelection(doc, mats):                                                    #Checks selection & returns a list of only the Octane materials
            oct_mats = []        #Create an empty list, to later store any Octane materials
            if mats:        #If there are any materials selected...
                count  = len(mats)                                                        #...get how many
                for i in range(count):                                                    #for each one...
                    if mats[i].GetType() == ID_OCTANE_MATERIAL:                           #...if it's an Octane material...
                        oct_mats.append(mats[i])                                          #...add it to our list of Octane materials
            return oct_mats                                                               #Return the list of Ocatne mats
        def GetTexture(doc, oct_mat, channel):                                            #Gets a filename from a particular channel of an Octane mat
            image_name = None                                                             #Create an empty variable to store the image name
            image_shader = oct_mat[channel]                                               #Check the texture link & load shader in variable image_tex
            if image_shader:                                                              #If one is found...
                shader_type = image_shader.GetType()                                      #...get it's type
                if shader_type == ID_OCTANE_MULTIPLY_TEXTURE:                             #If it's a multiply shader...
                    image_shader = image_shader[c4d.MULTIPLY_TEXTURE1]                    #Get the first shader in it
                    if image_shader:                                                      #If we found a shader of some sort
                        shader_type = image_shader.GetType()                              #Load it's type into the tex_type variable
                if shader_type == ID_OCTANE_MIXTEXTURE:                                   #If it's a mix shader...
                    image_shader = image_shader[c4d.MIXTEX_TEXTURE1_LNK]                  #Get the first shader in it
                if shader_type == ID_OCTANE_COLORCORRECTION:                              #If it's a colour correction shader
                    image_shader = image_shader[c4d.COLORCOR_TEXTURE_LNK]                 #Get the texture in it's texture link & replace the image_tex var
                if shader_type == ID_OCTANE_INVERT_TEXTURE:                               #If it's an invert shader
                    image_shader = image_shader[c4d.INVERT_TEXTURE]                       #Get the texture in it's texture link & replace the image_tex var
                        shader_type = image_shader.GetType()                              #Get it's type
                if shader_type == ID_OCTANE_IMAGE_TEXTURE:                                #If after checking all this, we have an image texture shader..
                    image_name = image_shader[c4d.IMAGETEXTURE_FILE]                      #Read the filename into the image_link variable
                    print image_name
            return image_name                                                             #Return the filename, if found
        def ReAssign(doc, oct_mat, c4d_mat):                                              #Assigns the new Cinema 4D material to the texture tags
            obj_link = oct_mat[c4d.ID_MATERIALASSIGNMENTS]                                #Get the link list for the Octane Material's assignment
            link_count = obj_link.GetObjectCount()                                        #Get how many objects are in the link list
            for i in range(link_count):                                                   #For each of them...
                tex_tag = obj_link.ObjectFromIndex(doc, i)                                #Get the texture tag
                doc.AddUndo(c4d.UNDOTYPE_CHANGE, tex_tag)                                 #Add an undo for the tex tag change
                tex_tag[c4d.TEXTURETAG_MATERIAL] = c4d_mat                                #Replace the Octane Material with the Cinema 4D material
                tex_tag.Message(c4d.MSG_CHANGE)                                           #update the tex tag
        def RebuildMats(doc, oct_mats):                                                   #Rebuilds each Octane material as a Cinema 4D material
            c4d_mats = []        #Create an empty list where we store our new Cinema 4D mats
            count = len(oct_mats)                                                         #Get how many Octane mats we have
            for i in range(count):                                                        #For each one...
                oct_mat = oct_mats[i]                                                     #Read the Octane Material into the variable oct_mat
                c4d_mat = c4d.BaseMaterial(c4d.Mmaterial)                                 #Create a new Cinema 4D material
                name = oct_mat[c4d.ID_BASELIST_NAME]                                      #Read the Material's name from the Octane mat...
                c4d_mat[c4d.ID_BASELIST_NAME] = name                                      #...and name the c4d material the same
                diff_file = GetTexture(doc, oct_mat, c4d.OCT_MATERIAL_DIFFUSE_LINK)       #Get the texure filename from the diffuse channel
                if diff_file:                                                             #If we did find a texrure filename...
                    diff_shader = c4d.BaseShader(c4d.Xbitmap)                             #...create a new empty bitmap shader...
                    diff_shader[c4d.BITMAPSHADER_FILENAME] = diff_file                    #...and load the filename in there
                    c4d_mat[c4d.MATERIAL_COLOR_SHADER] = diff_shader                      #Assign the bitmap shader to the material's colour channel...
                    c4d_mat.InsertShader(diff_shader)                                     #...and insert it into the material
                opac_file = GetTexture(doc, oct_mat, c4d.OCT_MATERIAL_OPACITY_LINK)       #Get the texture filename from the opacity channel
                if opac_file:                                                             #If we found one...
                    opac_shader = c4d.BaseShader(c4d.Xbitmap)                             #...create a new empty bitmap shader...
                    opac_shader[c4d.BITMAPSHADER_FILENAME] = opac_file                    #...and load the filename in there
                    c4d_mat[c4d.MATERIAL_ALPHA_SHADER] = opac_shader                      #Assign the bitmap shader to the material's alpha channel...
                    c4d_mat.InsertShader(opac_shader)                                     #...and insert it into the material
                    c4d_mat[c4d.MATERIAL_USE_ALPHA] = True                                #Activate the alpha channel
                normal_file = GetTexture(doc, oct_mat, c4d.OCT_MATERIAL_NORMAL_LINK)      #Get the texure filename from the normal channel...
                if normal_file:                                                           #If we found one...
                    normal_shader = c4d.BaseShader(c4d.Xbitmap)                           #...create a new empty bitmap shader
                    normal_shader[c4d.BITMAPSHADER_FILENAME] = normal_file                #...and load the filename in there
                    c4d_mat[c4d.MATERIAL_NORMAL_SHADER] = normal_shader                   #Assign the bitmap shader to the material's mormal channel...
                    c4d_mat.InsertShader(normal_shader)                                   #...and insert it into the material
                    c4d_mat[c4d.MATERIAL_USE_NORMAL] = True                               #Activate the normal channel
                bump_file = GetTexture(doc, oct_mat, c4d.OCT_MATERIAL_BUMP_LINK)          #Get the texure filename from the normal channel...
                if bump_file:                                                             #If we found one...
                    bump_shader = c4d.BaseShader(c4d.Xbitmap)                             #...create a new empty bitmap shader
                    bump_shader[c4d.BITMAPSHADER_FILENAME] = bump_file                    #...and load the filename in there
                    c4d_mat[c4d.MATERIAL_BUMP_SHADER] = bump_shader                       #Assign the bitmap shader to the material's mormal channel...
                    c4d_mat.InsertShader(bump_shader)                                     #...and insert it into the material
                    c4d_mat[c4d.MATERIAL_USE_BUMP] = True                                 #Activate the normal channel
                rough_file = GetTexture(doc, oct_mat, c4d.OCT_MATERIAL_ROUGHNESS_LINK)    #Get the texure filename from the roughness channel...
                if rough_file:                                                            #If we found one...
                    rough_shader = c4d.BaseShader(c4d.Xbitmap)                            #...create a new empty bitmap shader
                    rough_shader[c4d.BITMAPSHADER_FILENAME] = rough_file                  #...and load the filename in there
                    c4d_mat[c4d.MATERIAL_USE_REFLECTION] = True                           #Activate the Reflectance channel
                    c4d_mat[mainLayerId + c4d.REFLECTION_LAYER_MAIN_DISTRIBUTION] = 2     #Change the Default Specular to a Beckmann type
                    c4d_mat[mainLayerId + c4d.REFLECTION_LAYER_MAIN_SHADER_ROUGHNESS] = rough_shader
                    c4d_mat.InsertShader(rough_shader)                                    #...and insert it into the material
                ReAssign(doc, oct_mat, c4d_mat)                                           #Assign the new Cinema material inplace of the Octane one
                c4d_mats.append(c4d_mat)                                                  #Add the new mat to our list of Cinema 4D materials
                doc.InsertMaterial(c4d_mat)                                               #Insert the Cinema 4D Material in the document
                doc.AddUndo(c4d.UNDOTYPE_NEW, c4d_mat)                                    #Add an undo step for the new material
            my_doc = documents.GetActiveDocument()                                        #Get the active document
            my_mats = my_doc.GetActiveMaterials()                                         #Get the selected materials
            my_oct_mats = CheckSelection(my_doc, my_mats)                                 #Checks the selected mats & returns only the octane ones
            if my_oct_mats:                                                               #If we did find Octane materials...
                doc.StartUndo()                                                           #Start the undo chain
                RebuildMats(my_doc, my_oct_mats)                                          #...re-create them as Cinema 4D mats
                doc.EndUndo()                                                             #End the undo chain
                c4d.EventAdd()                                                            #Add an event
        • G Offline
          Graeme
          Another link to the Otoy forums:
          https://render.otoy.com/forum/viewtopic.php?f=87&t=56039
          • r_giganteR Offline
            r_gigante
            Hi Shellan, thanks for reaching out us.
            With regard to such Octane-specific topic, we recommend you to check with the official Octane Render support community.
            Best, Riccardo
            • S Offline
              sheilan
              @Graeme Thank you very much!
              @r_gigante Will do, thanks.
