    Melting Edges
    3 Posts 2 Posters 942 Views 1 Watching
    • R Offline
      rui_mac
      I have some code that identifies angles between faces that share an edge.
      I would like to build a list of all the edges that pass a certain criteria and then melt them all.
      How can I get the index of all those vertexes (I just have the two points that define each one), and select them to perform a melt command?
      • r_giganteR Offline
        r_gigante
        Hi @rui_mac, thanks for reaching out us.
        With regard to your question I recommend to use:
        • CPolygon::EdgePoints() to retrieve the vertex belonging to an edge
        • SendModellingCommand: see here on how it is used with regard to melting points.
        Best, Riccardo
        • R Offline
          rui_mac
          Thank you so much.
          I was thinging that I had to provide an edge index.
          Never thought that it would just require to select the points that define the edges.
          Great!!! 👍
