    Treeview adding a new item as an child
    pythonr20
    4 Posts 3 Posters 1.2k Views 1 Watching
    • P Offline
      pim
      I have seen the excellent post of Maxime about creating a Treeview.
      See https://developers.maxon.net/forum/topic/10654/14102_using-customgui-listview/2
      There is an Add button, but now I want to add it as a child.
      I added a Insert Under button with following code in Command().
              if id == 1002:
                  # Insert Under
                  tex = TextureObject("Inserted under first item.")
                  first = self._listView.GetFirst(self._treegui, self._listView)
                  #InsertObject(self, root, userdata, obj, dragtype, dragobject, insertmode, bCopy):
                  self._listView.InsertObject(self._treegui, self._listView, first, c4d.DRAGTYPE_FILENAME_OTHER, tex, c4d.INSERT_UNDER, True)
                  # Refresh the TreeView
                  self._treegui.Refresh()
      And in class ListView(c4d.gui.TreeViewFunctions) I added
          def GetFirst(self, root, userdata):
              rValue = None if not self.listOfTexture else self.listOfTexture[0]
              return rValue
          def InsertObject(self, root, userdata, obj, dragtype, dragobject, insertmode, bCopy):
      But nothing is inserted.
      I think it is because of InsertObject(), because nothing is inserted in the _listView.
      So, how to insert it as a child?
      -Pim
      • r_giganteR Offline
        r_gigante
        Hi Pim thanks for reaching out us.
        With regard to your request, rather than implementing TreeViewFunctions::InsertObject() you should take care of implementing a TreeViewFunctions::GetDown() and also to redesign the data type being responsible to store the TreeView items and their children.
        In the case presented by @m_adam a simple list was used and this was sufficient for the scope of representing a one-level tree. Also accessing the next/prev items was done by searching for the index of a given item in the list which turned to be quick and slick.
        Last but not least it's also relevant to implement a TreeViewFunctions::Open()and TreeViewFunctions::IsOpened() in order to properly manage the folding/unfolding functionality otherwise your tree might appear always folded
        Hope these few notes can lead you through the right direction.
        Best, Riccardo
          mp5gosu
          I'd like to add that using GeListNode and GeListHead is convenient since they already come with all functions you need.
          r_giganteR 1 Reply Last reply Reply Quote 0
            r_gigante @mp5gosu
            @mp5gosu this completely makes sense and it's indeed a valuable recommendation but I wasn't sure about Pim's requirement here on deriving from Cinema 4D base classes.
            Cheers, R
