    Baking textures for PBR object
    2 Posts 2 Posters 1.0k Views 1 Watching
    • K Offline
      krfft
      Is it possible to bake the values of the reflection channel into textures using "Bake object"?
      • r_giganteR Offline
        r_gigante
        Hi krftt thanks for reaching out us.
        With regard to your question, if the intent is to bake the final appearance of a PBR material on a texture, I confirm that there are no means to achieve this considering that the baked data will also be camera-dependent.
        If, on the contrary, your goal is to sample the shader used in any of the reflection layers used in a PBR material you can consider BaseShader::Sample() and, given a ChannelData, retrieve the color at a specific point - see this thread.
        To browse through the different channel you can use something like:
            # check for an active material
            mat = doc.GetActiveMaterial()
            if mat is None:
            # retrieve the reflection layers count
            layersCount = mat.GetReflectionLayerCount()
            # loop through the layers
            for i in xrange(layersCount):
                # get the ReflectionLayer instance and the related data ID
                reflLayer = mat.GetReflectionLayerIndex(i)
                reflLayerData = reflLayer.GetDataID()
                # check for the instance to be the one currently active in the Attribute Manager
                if reflLayer.GetFlags() & (c4d.REFLECTION_FLAG_TAB):
                    # retrieve the color
                    color = mat[reflLayerData + c4d.REFLECTION_LAYER_COLOR_COLOR]
                    # try to retrieve the shader
                    colorShader = mat[reflLayerData + c4d.REFLECTION_LAYER_COLOR_TEXTURE]
                    # do something with the data retrieved
                    if colorShader is None:
                        print "Selected layer is ", reflLayer.GetName(), "and uses color: ", color
                        print "Selected layer is ", reflLayer.GetName(), "and uses shader: ", colorShader.GetName()
        Best, Riccardo
