    BuildNgon() with only two inner edges crashes
    Cinema 4D SDK
    c++ r20 classic api
    1.2k
    • fwilleke80F
      fwilleke80
      Porting code again... this seemed to work years ago:
      ngonBase->BuildNgon(innerEdges, NULL, 2, 0, polygonsDest, pointsDest);
      An array with 2 inner edge indices is passed, and BuildNgon() should construct an Ngon around them.
      In R20, I am getting crashes with the following console output:
      /Volumes/Branches/build_osx/osx-4-release/depot/release/20.0/modules/model/source/dave/modeling/ngonbase.cpp(1450): CRITICAL: Stop: Degenerated Ngon Creation, an Ngon must have at least 5 vertices.
      I am well aware that the actual reason for the crash might be somewhere else... but I want to understand what's going on here. Under which conditions exactly is this error thrown? When are there less than 5 vertices in the Ngon?Does it have anything to do with the topography of the surrounding polygons?
      Thank you & greetings,
      Frank
      www.frankwilleke.de
      • r_giganteR
        r_gigante
        Hi Frank, thanks for reaching out us.
        Can you please provide us with a code snippet to reproduce the Critical Stop?
        Thanks, Riccardo
        • fwilleke80F
          fwilleke80
          Hmm, I'll try to make something up. The project is non-public code and part of a bigger project.
          But even without a code snippet, you might know about any changes, as the code used to work.
          If I pass only one inner edge, consisting of 2 vertices, to BuildNgon(), which definitely has either a quad or a triangle at each of its sides, what could go wrong?
          Frank
          www.frankwilleke.de
          • fwilleke80F
            fwilleke80
            I noticed it's a different error message sometimes.
            So here goes my next question: Under which circumstances does BuildNgon() print the following error message:
            /Volumes/Branches/build_osx/osx-4-release/depot/release/20.0/modules/c4dplugin/source/src/christian/ge_register.cpp(244): WARNING: Unknown baselist allocator - RegID: OBJECT
            Optout defined by Installer / Updater.
            Thanks & greetings,
            Frank
            www.frankwilleke.de
            • fwilleke80F
              fwilleke80
              Oh, it turns out, the last message wasn't triggered by our code. It appears anyway 😉
              www.frankwilleke.de
              • r_giganteR
                r_gigante
                Hi Frank, thanks for following up.
                With regard to
                it has actually nothing to do with BuildNgon()
                With regard to
                it takes place if the code identifies a potential situation where the number of outer edges ( computed from the list of the inner edges ) is lower than 5 which then could create degenerate ngons (since they should be quads).
                This check has been recently introduced to avoid that 4-sides degenerated ngons were created in place of quads.
                Best, Riccardo
                • fwilleke80F
                  fwilleke80
                  Hi Ricardo!
                  OK, thanks! If there a way to ask the Ngon system for more information about that?
                  Or do we have to recreate parts of the Ngon creation algorithm to find predict degenerate Ngons before calling BuildNgon() ?
                  Frank
                  P.S.: Sorry for the late reply!
                  www.frankwilleke.de
                  • r_giganteR
                    r_gigante
                    Hi Frank, thanks for following up 🙂
                    With regard to your latest question, there are no means to "ask" the Ngon system about that.
                    Checking for the number of vertexes an n-gon is going to use before deciding to use it, it's a reasonable way to proceed.
                    Cheers, Riccardo
