    Precise float parameters in UI
    c++r20sdk
    4 Posts 4 Posters 972 Views 1 Watching
    • P Offline
      peterakos
      Hello.
      I use REAL in Description Resource files.
      But in NodeData's Interface, this value cannot be set with high precision such as 0.0000001.
      Is there anything I can do to fix this ?
      Thank you very much for your time.
        mp5gosu
        With Interface, do you mean the Gui part?
        If so, you can actually set with the maximum allowed precision. Although, Cinema 4D doesn't reflect that in cutting off the last digits, the value is still preserved.
        • r_giganteR Offline
          r_gigante
          Hi Peterakos, thanks for reaching out us.
          With regard to your request, confirming what @mp5gosu has already pointed out in terms of internal precision kept Cinema, at the moment you can only get it fixed in a CustomGui.
          At the same time, this limitation is known and already tracked in our bug handling system.
          Best, Riccardo
          rsodreR 1 Reply Last reply Reply Quote 1
          • rsodreR Offline
            rsodre @r_gigante
            Shouldn't STEP be used to set this precision?
            Or is there a limit for STEP?
