    Source Processor: Platform-dependent function signatures
    Cinema 4D SDK
    c++ r20
    • fwilleke80F
      fwilleke80
      the source processor is throwing an error for this constructor:
      #ifdef __APPLE__
      CBlowFish::CBlowFish(const unsigned char* ucKey, unsigned int keysize, const SBlock& roChain, bool backwardsCompatibility_) : m_oChain0(roChain), m_oChain(roChain)
      #else
      CBlowFish::CBlowFish(const unsigned char* ucKey, size_t keysize, const SBlock& roChain) : m_oChain0(roChain), m_oChain(roChain)
      #endif
      The error is:
      error: Expected ',' or '{', found 'CBlowFish' instead.
      I know the source processor does not parse preprocessor statements, so yes, this might look like a syntax error to it. But it's not. This had always worked, and still does. So how can I tell the source processor to shut up about it? 😉
      Thanks in advance,
      Frank
      www.frankwilleke.de
      • fwilleke80F
        fwilleke80
        I managed to get rid of the error by adding this line to projectdefinition.txt:
        DontUncrustify="blowfish.cpp"
        But since this disables all source processor activity on this file, as I understood it, I wonder if there is no "cleaner" way to suppress just this one false error.
        www.frankwilleke.de
        • r_giganteR
          r_gigante
          Hi Frank, thanks for reaching out us.
          With regard to the reported issue, which I suppose it's happening on your side, you can consider, rather than disabling uncrustifying, modifying your code as:
          #ifdef _APPLE_
          #endif
          Looking forward to see if it works for you, give best.
          Riccardo
          • fwilleke80F
            fwilleke80
            Hi Riccardo,
            thank you! I'll try that.
            Admittedly, it doesn't really improve code readability 😉
            Best greetings,
            Frank
            www.frankwilleke.de
            • fwilleke80F
              fwilleke80
              It builds, and the source processor does not complain. Thank you!
              www.frankwilleke.de
