    BaseLink & Document Copy
    SDK Help
    0
    • H
      On 01/06/2003 at 12:15, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hello !
      I have a plug that stores a baselink to an object. When the document is copied (when rendering in a window), does the link points to the copied object in the copied document or does it points to the original object in the original document?
      Thanks for helping ! 🙂
      • H
        On 02/06/2003 at 01:25, xxxxxxxx wrote:
        First of all, please resolve the conflicting SDK versions in your header/footer. I'm assuming you're using 8.100, since there are no BaseLinks in 6.3.
        When the document is copied the new base links point to the new document, since AliasTranslator::Translate() is called with connect_oldgoals set to TRUE.
