    Radiobuttoneffect in VP-Plugins
    2 Posts 0 Posters 320 Views
      On 29/05/2003 at 06:29, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I need a radiobutton-effect that is working with checkboxes. I finished my layout and everything is working fine but know I need for two checkboxes a radibutton-effect, that means that when one is active the other one isn't active. I don't want to do it with a selection list.
      Where must I put in the code with the if/else question? I tested it in the init menue but it isen't working because this give me back only the start settings and not the modified settings and then I get my settings in the execute function but thats too late becasue I want that one checkbox is off and the other is one and when you change it that the check is springing.
      thanks
      Cathleen
        On 01/06/2003 at 10:27, xxxxxxxx wrote:
        See if MSG_DESCRIPTION_VALIDATE works.
