    Getting points and edges of parametric objects
    5 Posts 2 Posters 1.9k Views 2 Watching
    • K Offline
      kalugin
      Hi folks. Is there a way to use the "GetNearest" functions on parametric objects ? Like Cube and Sphere and so on.
      ViewportSelect.GetNearestEdge(op, x, y, maxrad=MAXLONGl, onlyselected=False, ignorelist=None, ignorecnt=0)
      If the target object is not editable I get:
      RuntimeError: Object is not initialized yet
      I've tried currentstate and makeeditable, but the result is the same.
      • Passion3DP Offline
        Passion3D
        Hi Kalugin
        A parametric object cannot be used in point, edge or polygon mode. You need to convert it to a polygonal object
        • K Offline
          kalugin
          what if I want to code my own snapping ? How can you snap to points of parametric objects ?
            Passion3D
            Make a clone, which you then delete, which serves as a reference and reports the coordinates on your parametric object.
            This is the principle I use in my OnFloor plugin, to position a parametric object on the ground.
            • K Offline
              kalugin
              Nevermind. I figured it out 🙂 It was my mistake in the code. I made myself a helper function to initialize the ViewportSelect object, and I was initializing it with the wrong object. That's where the runtime error came from. Thanks anyway.
