    Global to Local pos
    9 Posts 2 Posters 1.9k Views 2 Watching
    • Passion3DP Offline
      Passion3D
      Hi
      How to convert global position to local.
      I want to convert global position of Object to local position of his parent
        mp5gosu
        Here you will find any information about matrices and thus everything about positioning, scaling, rotation, etc.
          Passion3D
          I'm not an expert in math ๐Ÿ˜‰ i tried but don"t work
          My english is null and google translate isn't always correct
          Can you give me an example?
            mp5gosu
            No problem. ๐Ÿ™‚
            Now to your question: You can simply call GetMl() on your child object. This returns you the local matrix of the object. Now to access the position, ask the matrix for the offset:
            myObject.GetMl().off
            It's the very first example code in the documentation I linked in my previous post.
            @passion3d said in Global to Local pos:
            You should try Deepl
              Passion3D
              My question may not be clear enough.
              I have an object1 that has a child Object2
              I want to move Object2 to a global position, so I have to convert the global position from destination to local position with respect to its parent.
                mp5gosu
                You don't have to!
                There's also a function available: SetMg()
                I warmly suggest you to read the Matrix Fundamentals since it has been written to demystify the matrix math. It also has various code examples for all kinds of transformations, including your scenario.
                edit: Now that I think about your question: Do you want to move the parent with the child?
                  Passion3D
                  no, i want move the child but not the parent
                    mp5gosu
                    Sorry, got you slightly wrong then.
                    Try this:
                        m = op.GetMg() # get the object's matrix
                        m.off = c4d.Vector(50) # modify the position
                        op.SetMg(m) #set the modified matrix
                        c4d.EventAdd() # update C4D
                    This code simply moves the child, completely decoupled from its parent in absolute world coordinates.
                      Passion3D
                      Thank you @mp5gosu ๐Ÿ˜‰
                      This is exactly what I was looking for.
                      In fact, C4D does the calculations itself. I thought I had to do the matrix multiplication, and I didn't understand how to do it.
                      Finally it's very simple ๐Ÿ™‚
