    Bitmap Button
    14 Posts 2 Posters 3.2k Views 1 Watching
    • merkvilsonM Offline
      merkvilson
      Seems like I figured it out but I'll keep investigating.
        merkvilson
        I tried this way and it kinda works. but let's assume that I want to scale the sphere object from my object generator plugin. It works only if I'm updating the render settings or reloading python plugins. Is it possible to update it according to the DIRTY FLAGS of the object generator plugin?
        let me know if I'm doing something wrong.
        • S Offline
          s_bach
          you could set DIRTYFLAGS_DESCRIPTION after an interaction with the TEST_SLIDER parameter (e.g. in SetDParameter or after MSG_DESCRIPTION_POSTSETPARAMETER). That should update the description.
          merkvilsonM 1 Reply Last reply Reply Quote 1
            merkvilson @s_bach
            @s_bach
            SetDParameter seems to be easier but seems like I'm doing something wrong. Can you provide a code snippet, how to do this properly?
              merkvilson
              I'm probably doing something wrong.
                  def SetDParameter(self, node, id, t_data, flags) :
                      if id[0].id == c4d.TEST_SLIDER:
                          node.SetDirty(c4d.DIRTYFLAGS_DESCRIPTION)
              • S Offline
                s_bach
                it seems to work better if you change the dirty status of the bitmap. Something like this:
                def GetDParameter(self, node, id, flags):
                    if id[0].id == c4d.THE_BITMAP_BUTTON:
                        data = c4d.BitmapButtonStruct(node, id, self.bmp.GetDirty())
                        return (True, data, flags | c4d.DESCFLAGS_GET_PARAM_GET)
                def SetDParameter(self, node, id, t_data, flags):
                    if id[0].id == c4d.THE_OTHER_PARAMETER:
                        self.bmp.SetDirty()
                        node.SetDirty(c4d.DIRTYFLAGS_DATA)
                    return False
                  merkvilson
                  This post is deleted!
                    merkvilson
                      merkvilson
                        merkvilson
                        btw, is it possible to prevent the description from constant updates during manipulating the slider and set the DIRTYFLAGS when the slider is already set to the desired value?
                        Seems like C4D's material preview is capable of detecting time intervals between manipulations and if the interval is not high enough, no update takes place. Should I import pythons datetime or maybe it is possible to accomplish this task directly from c4d's module?
                          merkvilson
                          This goes off topic so I'll make a new post.
                          The main issue is already solved, thanks to Sebastian! 💙
