    Parameters for commandData Plugin
    pythonr20windows
    3 Posts 2 Posters 762 Views 1 Watching
    • B Offline
      Boony2000
      Hi!
      Is it possible to add a commandData plugin multiple times to a menu, but label it differently and pass a parameter to Execute()? Or is the only way to do that via GetSubContainer()?
      I'm thinking of something like
      menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_12345, menuLabel1, menuParam1)
      menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_12345, menuLabel2, menuParam2)
      to then do something like this in Execute
      def Execute(self, doc, param):
          if param == x:
              doX()
          elif param == y:
              doY()
      Thanks!
      • S Offline
        s_bach
        you cannot add a new argument to the Execute() function.
        Instead, you could write a more generic CommandData plugin that stores an internal value. You could register different versions of that command using different plugin IDs and then call these different versions. Something like this:
        class DynamicCommand(plugins.CommandData):
            # internal value
            _setting = 0
            def __init__(self, setting):
                # set internal value on creation
                self._setting = setting
            def Execute(self, doc):
                # use internal value on execution
                print(self._setting)
        Which can be registered using constructors with different arguments:
        plugins.RegisterCommandPlugin(id_a, "Command A", c4d.PLUGINFLAG_HIDEPLUGINMENU, bitmaps.BaseBitmap(), "", DynamicCommand(123))
        plugins.RegisterCommandPlugin(id_b, "Command B", c4d.PLUGINFLAG_HIDEPLUGINMENU, bitmaps.BaseBitmap(), "", DynamicCommand(456))
        • B Offline
          Boony2000
          Hi Sebastian!
          Thanks for your answer. I was looking for something a little more flexible than registering multiple plugins, but I guess GetSubContainer will have to do šŸ™‚
