    Oriented Bounding Box
    SDK Help
    0
    • H
      On 25/05/2003 at 10:07, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;
      Is there any in-built routine to calculate if the oriented Bounding Boxes of two objects intersect?
      With oriented bounding boxes I mean the bounding boxes that are around the objects when they are oriented by 0,0,0 but that are rotated when the object is rotated too. Is this clear? 😉
      Thank you very much in advance.
      Rui Batista
      • H
        On 25/05/2003 at 13:43, xxxxxxxx wrote:
        No. (And especially not in C.O.F.F.E.E... 😉
        • H
          On 26/05/2003 at 03:14, xxxxxxxx wrote:
          Ok, back to my net search 😞
          By the way, when will COFFEE get an overhaul?
          Rui Batista
          • H
            On 16/09/2004 at 19:03, xxxxxxxx wrote:
            I'd like to hear the answer to that one myself Rui.  Anybody?
            • H
              On 17/09/2004 at 06:55, xxxxxxxx wrote:
              Answer:
              Take the object/hierarchy points (GetPointCount() and GetPoints()) and determine the default Bounding Box. The points retrieved from objects are not transformed and therefore represent the untransformed object.
              Once you have the Bounding Box points, use object->GetMg() and apply it to its points (assuming the use of a PointObject for the Bounding Box) :
              var mat = object->GetMg();
              for (i = 0; i < 8; i++)
              bndBox->SetPoint(i) = mat->GetMulP(bndBox->GetPoint(i));
              This will transform the points to be oriented similarly to the object.
              Then perform intersection tests as usual. General 3D intersection tests are somewhat complicated (as compared to axis-aligned bounding box ones). You will need to test for volume-volume intersection. Check out Graphics Gems and Game Programming Gems for solutions.
              Robert
              • H
                On 17/09/2004 at 09:00, xxxxxxxx wrote:
                Addendum:
                Just thought to mention that if you only calculate an axis-aligned bounding box on the objects' transformed points (using Mg), you can use the simple method of intersection testing, at least a first elimination test. This method quickly eliminates objects that in no way intersect.
                It is just a matter of determining the 'minimum' and 'maximum' values on each axis (XYZ), and testing thusly:
                if ((obj1minX < obj2minX) && (obj1maxX < obj2minX)) // no intersection
                else if ((obj1minX > obj2maxX) && (obj1maxX > obj2maxX)) // no intersection
                else if ((obj1minY < obj2minY) && (obj1maxY < obj2minY)) // no intersection
                else if ((obj1minY > obj2maxY) && (obj1maxY > obj2maxY)) // no intersection
                else if ((obj1minZ < obj2minZ) && (obj1maxZ < obj2minZ)) // no intersection
                else if ((obj1minZ > obj2maxZ) && (obj1maxZ > obj2maxZ)) // no intersection
                // otherwise there is a possible intersection - definite bounding box intersection
                Robert
