    Changing Points for existing Polys
    3 Posts 0 Posters 372 Views
      On 25/05/2003 at 09:13, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I´m pretty new at programming coffee, and I´ve been trying for some time now to change the point-allocation for existing polygons (eg. polygon 0: points 0, 1, 2, 0; change it to polygon 0: points 5, 6, 7, 5; just like it is displayed in the structure manager). How do I set this information? (I looked both into the "Create a polyobject using C.O.F.F.E.E." and "Simple Polygon Problem" threads, but unfortunately I could not figure out how to do this).
      Any help would be appreciated.
      MikeI
        On 26/05/2003 at 01:03, xxxxxxxx wrote:
            var p = obj->GetPolygon(0);
            p.a = 5; // Perhaps this should be -> instead of .
            p.b = 6;
            p.c = 7;
            p.d = 5;
            obj->SetPolygon(0, p);
            obj->Message(MSG_UPDATE);
          On 26/05/2003 at 01:22, xxxxxxxx wrote:
          Thanks, that did the job, now it works like a charm. I had some similar code in my plugin, but like your first version I used p.a to set the polygons, but you need to use p->a to get it working.
