    Mac build fails, PC build OK
    8 Posts 3 Posters 1.4k Views 2 Watching
    • C4DSC Offline
      C4DS
      I have converted an R16-R19 plugin to R20 on PC.
      After resolving all compiler issues. I copy the adjusted source files, res files to Mac.
      There the build reports
      No viable conversion from 'maxon::Bool' (aka 'bool') to 'Result<void>'
      and this for line 2286 in apibase.h
      Result<void> res = dst.CopyFrom(src);
      It seems related to a class I provided, disallowing copy and assign. And for which I have provided a CopyFrom method.
      Strangly enough, I have provided
      class MyObject
      MAXON_DISALLOW_COPY_AND_ASSIGN(MyObject);
      maxon::Bool CopyFrom(const MyObject& src);
      A return type of maxon::Bool, which is also mentioned in the Code Style Guide point 9.6.
      while the R19 documentation indicates
      MAXON_WARN_UNUSED Result<void> CopyFrom(const Example1& src)
      Looking at my code, it seems I got it wrong.
      The R16-R19 implementation uses a Bool as return type, while it should be a Result<void>, still all compiles fine, and runs fine as well. (both PC and Mac)
      The R20 implementation uses a Bool, which should be OK according to the documentation, compiles fine on PC but that fails to compile on Mac.
      EDIT:
      The R20 SDK example (Move/Copy Constructors) also contains:
      maxon::Result<void> CopyFrom(const Example3& src)
      I am confused
      • C4DSC Offline
        C4DS
        Think I got it resolved.
        Seems the correct implementation should indeed be
        as the arraytutorial.cpp and movecopyconstructor.cpp examples from the R20 SDK indicate.
        Please update the Code Style Guide point 9.6 to show the correct way to go for a CopyFrom.
        Thanks for watching.
        • C4DSC Offline
          C4DS
          I had a "deja vu" moment, and indeed ... seems I already once hit that same wall here
          Funny that Visual Studio never once complained about the maxon::Bool CopyFrom.
          • C4DSC Offline
            C4DS
            Bringing this back to the attention, as it might have been lost during the holiday period.
            The Code Style Guide (section 9.6) shows
            class Test
              MAXON_DISALLOW_COPY_AND_ASSIGN(Test)
            private:
              Int _value[5];
            class Test
              Bool CopyFrom(const Test& source);
            private:
              Int _value[5];
            where the CopyFrom should actually not return a Bool but a maxon::Result<void>.
              mp5gosu
              This is probably due to the Docs have not been updated in this regard.
              maxon::Result<> is indeed correct. You can look it up here: https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_transition.html#page_maxonapi_transition_code_error
              • C4DSC Offline
                C4DS @mp5gosu
                @mp5gosu
                I know, that's why I mention it again ... to please update the Code Style code snippet.
                • a_blockA Offline
                  a_block
                  we are sorry, you ran into this issue, especially as our guide seems to have led you on a wrong path. And I apologize, we (although I'd rather blame the bearded guy with red coat) obviously did miss your post. Sorry!
                  We'll see to get the code style guide updated.
                  Andreas
                  C4DSC 1 Reply Last reply Reply Quote 1
                  • C4DSC Offline
                    C4DS @a_block
                    @a_block
                    No need for apologies.
                    I thought the bearded guy had something to do with it ...
                    Hence the reason I posted the message again. Luckily, JIT before the easter bunny was to blame.
