    Project tool and non-cpp file extensions
    4 Posts 2 Posters 1.4k Views 1 Watching
    • S Offline
      sgeggie
      I'm using the project tool to build a plugin. I'd like to reuse a library built in my regular project structure, but I'm having a bit of trouble adding it to the Project Tool structure.
      Critically, it seems like source files added to a project with "Include.Win=" must have either .h or .cpp extensions. At least, all of the files I try to add with a .cc extension aren't taking.
      I should also mention that I am adding files outside of the sdk directory using "../../../../../" style paths, which I know is not recommended, but has worked well for all of my .cpp files. Could this be the problem?
      Before I start extensively copying and renaming, is my assumption correct? Is there no way to force the tool to add a .cc file to my project? If so, is this documented anywhere?
      Regards,
      Sean
      • a_blockA Offline
        a_block
        Hi Sean,
        I'm afraid currently the project tool does not consider .cc extensions. I'm also not aware of any option.
        But I asked our development, if there might be a hidden option and otherwise it could be considered for a future version of the project tool. I'll keep you updated here.
        Andreas
        • a_blockA Offline
          a_block
          Update: Support for .cc file extension was added and will come with the next release of the project tool.
          • S Offline
            sgeggie
            That's great, Andreas. Thanks! I'll kludge on until then.
