    ParseTupleAndKeywords in R20
    c++r20python
    5 Posts 2 Posters 1.4k Views 1 Watching
    • V Offline
      victor
      We are adding new Python functions to Cinema and our solution works fine in R19 and previous versions but we are having problems parsing the parameters in R20
      static _PyObject *MyprojectPyAPI_MakeThing(_PyObject *self, _PyObject *args, _PyObject *keywords)
      	PythonLibrary pylib;
      	String str;
      	const Char *kwlist[] = { "str", nullptr };
      	if (!pylib.ParseTupleAndKeywords(args, keywords, "$", kwlist, &str))
      		return nullptr;
        #if API_VERSION < 20000
      	  if (str.Content())
        #else
      	  if (str.IsEmpty()!=false)
        #endif
      		Utils::addLog("Parameter is: " + str);
      	else
      		Utils::addLog("Cannot parse the parameter correctly.");
      	return pylib.ReturnPyNone();
      As you can imagine the problem is that it always throws "Cannot parse the parameter correctly."
      Any idea on what is wrong for R20? something related to PythonLibrary changed?
      Thank you in advance!
      • Y Offline
        y_puech
        Hi Victor,
        Only minor changes/fixes have been made to the PythonLibrary and its behavior hasn't changed in R20. So parsing a String with $ should still work fine.
        How do you call the function and pass the string? What's the exact error message?
        Former MAXON SDK Engineer
        • V Offline
          victor
          I didn't change nothing from the version that works ok in R19
          moduleFunctions[0].Init("MakeThing", (PyFn)MyprojectPyAPI_MakeThing, PYFN_FLAGS::KEYWORDS, "MakeThing(str path)");
          • Y Offline
            y_puech
            Hi Victor,
            There's a logic error in the code you posted from the first post. The condition for R20 if (str.IsEmpty()!=false) returns false if the string has content.
            It makes more sense to call IsPopulated() for the R20 code instead of IsEmpty().
            V 1 Reply Last reply Reply Quote 3
            • V Offline
              victor @y_puech
              @y_puech said in ParseTupleAndKeywords in R20:
              Hi Victor,
              You are right, thank you!!!
