    import a coffee WriteReal with c++?
    2 Posts 0 Posters 296 Views
      On 10/05/2003 at 12:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:      Mac OSX  ;
      Hi Folks
      Ok, I'll try to write in english... I hope you're able to understand what my problem is 🙂
      In Coffee I've written "file->WriteReal(3.14);". Then I've sent the file to a friend of mine. The target would be that he is able to import that file with c++. But he gets only silly results, far away from 3.14 😕
      Do you know whether it is possible to import something from Coffee with standard-c++?
      May you can give me a hint...
      Thanks and greetings from Switzerland
      qwaak
        On 14/05/2003 at 14:56, xxxxxxxx wrote:
        Please check that you have set the correct byte order with BaseFile::SetOrder(). Then it should work.
