    Print console logs in terminal
    pythonr20
    5 Posts 2 Posters 2.7k Views 1 Watching
    • R Offline
      Rage
      Hi all,
      I'm developing an application that runs a python plugin in cinema4d from commandline. Here's the problem: I can't see the console prints. How do I make c4d to print the logs in the terminal console instead of its own (the internal one under script->console)?
      • Y Offline
        y_puech
        Are you using Cinema 4D release 20 commandline.app/exe? There's a known bug under investigation.
        The workaround is to use c4d.GePrint() instead of print().
        Note I moved the topic to Cinema 4D Development category.
        I also turned it into a Q&A. Please make use of this in the future. For more information see Q&A New Functionality.
        Former MAXON SDK Engineer
        • Y Offline
          y_puech
          There's a more convenient workaround than using GePrint().
          sys.__stdout__ original standard output stream can be used to redirect stdout and print to the terminal/console. Here's some code:
          # Stores the stdout redirected by Cinema 4D Python
          c4d_stdout = sys.stdout
          # Redirects to original stdout
          sys.stdout = sys.__stdout__
          # Prints something
          print("Some text to be printed to the terminal/console")
          # Restores Cinema 4D Python stdout redirection
          sys.stdout = c4d_stdout
          R 1 Reply Last reply Reply Quote 4
          • R Offline
            Rage @y_puech
            Thank you this works nicecly
            I'm using cinema 4D 20 student edition
            • Y Offline
              y_puech
              As I turned this discussion into a Q&A topic, if you're satisfied with my last post's solution then you can mark it as the correct answer or mark the topic as solved.
