    since i am not able to compile things for r20 on my computer here is the source...
    13 Posts 3 Posters 4.0k Views 1 Watching
    • E Offline
      ello @a_block
      @a_block ok, i managed to compile the sdk, now i added my old plugins and am facing a bunch of errors (837) and warnings (9747) which i guess is not that bad, since it seems to be more general stuff.
      • E Offline
        ello
        i stumble across quite some things that have been removed. but that is the only thing stated. nothing tells me what replaced it. for example:
        struct DescriptionCommand
          DescID id;  // Removed
        I had this code in my plugin:
        	if (type == MSG_DESCRIPTION_COMMAND) {
        		DescriptionCommand* data = reinterpret_cast<DescriptionCommand*>(t_data);
        		if (data)
        			if (data->id == LOAD_PRESET)
        				MessageDialog("Preset loaded."_s);
        			if (data->id == SAVE_PRESET)
        				Filename library_dir = GeGetC4DPath(C4D_PATH_LIBRARY_USER);
        				Filename preset_dir = library_dir + Filename("arKos") + Filename("presets")+Filename("p1.c4d");
        				if (savePreset(op, preset_dir)) MessageDialog("Preset saved."_s);
        				else MessageDialog("Saving failed."_s);
        one thing that is really mean, why could i multiply a vector with a matrix in the past (and it worked) and now i need to exchange a few hundred lines that the matrix stands before the vector? this is something i cannot understand (to me it is just a unnecessary change which gives absolutely no benefit)
        Edit a_block: Added code tags.
        • a_blockA Offline
          a_block
          Hi ello,
          I'm glad you made some progress and your mood seems to have improved a bit.
          In R20 (and actually it's a must for all new stuff being introduced by developers) many "anonymous" enums have been changed into named enums, leading to a change in how these symbols are reference.
          In your case it is SHADERINFO::BUMP_SUPPORT, so now the enum is named SHADERINFO and the contained symbols got shortened to the unique part.
          The background of this change is explained here: API Transition - Enumerations.
          I'd like to suggest to open new threads for specific questions, to keep the forum tidy and the thread's content more related to the actual subject.
          Edit: This wrote this before I saw your additional post. I'll get back to this additional post soon.
          Andreas
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            ello @a_block
            @a_block thank you for your time. i am indeed having a hard time adopting to all those changes 🙂
            • a_blockA Offline
              a_block
              Hi ello,
              DescID has not been removed, I'm not sure yet, why you are having issues using it. We'll get back to you tomorrow on this.
              Regarding Matrix and Vector multiplication, this was a change introduced with Cinema 4D R15. See List Of Name Changes in R15 API - Matrix Math. The reason is, that in mathematics there is nothing like a Vector multiplied from left to a Matrix. At least to my knowledge, I'm not an expert here (pretty sure a professor in mathematics will pop up here now, telling me I'm wrong).
              Please consider using the mark down and using code tags. I have added them to your previous post.
              Andreas
              • E Offline
                ello
                thank you... it is my first visit to the new plugin cafe, thus i need to learn how to tag my entries
                • E Offline
                  ello
                  maybe someone can point me towards how i debug with visual studio 2017?
                  because i get lot's of crashes 🙂 what else to expect
                  ok, found this: [URL-REMOVED]
                  edit: visual studio now throws this at me
                  application_Intel_64bit.pdb not loaded
                  the only search result leads me here: https://developers.maxon.net/forum/topic/8139 but i dont understand how the information i find there helps me
                    mp5gosu @ello
                    @ello said in since i am not able to compile things for r20 on my computer here is the source...:
                    Simply continue the execution twice. Those are 2 breakpoints that are triggered by Cinema 4D. Note that VS 2017 is not officially supported- maybe that's the cause. Those breakpoints are still risen, even if all breakpoints (and exceptions) are disabled.
                    Maybe someone is able to help us out here?
                    • a_blockA Offline
                      a_block
                      Hello ello
                      As I said in my previous post DescID has not been removed. I think, it may rather be a problem with a lacking include. Can please check if you do a #include <lib_description.h>?
                      This is just a warning and perfectly normal. We do not provide a .pdb (program database) file for the application itself. These files contain debug information for Visual Studio and would allow inspection of the application we don't want to happen in public.
                      It is also not related to the startup of Cinema 4D being interrupted twice. We are currently investigating the actual reason for these interruptions and hope to get them fixed with one of the next release. Sorry, for the inconvenience caused.
                      Andreas
                      • E Offline
                        ello
                        hm, in the sdk help it is mentioned under "api change list in r20"... scrolling down to lib_description.h
                        i installed VS2015 just for seeing if it works better with c4d. however, in 2017 i had a nice built output where i could sort errors and warnings. this isn't there in the 2015 version, or do i need to toggle it somewhere. cannot find
                        nevermind, found it 🙂
