    vd->TraceGeometry with Displacement
    6 Posts 0 Posters 751 Views
      On 06/05/2003 at 06:03, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      vd->TraceGeometry doesn't work for channel-shaders in the displacement-channel. Is this a know limitation? or a workaround available?
        On 11/05/2003 at 16:25, xxxxxxxx wrote:
        you need to switch on the raytracing flag for your shader.
        cheers
        Paul Everett
          On 12/05/2003 at 07:34, xxxxxxxx wrote:
          Hi Paul,
          The CHANNEL_RAYTRACING is flag on, otherwise TraceGeometry would not work.
          (and I have also tried SHADER_RAYTRACING)
          The problem is only in the displacement-channel, all other channels works without a problem.
            On 12/05/2003 at 07:46, xxxxxxxx wrote:
            i had a problem with this as well
            i just disabled  my shader for the displacement channel.
            thats how i got around it.
            do you really need your shader to work in displacement channel ?
            or is this just a problem cos it crashes?
            cheers
            Paul
              On 12/05/2003 at 08:04, xxxxxxxx wrote:
              fortunately there is no crash using the displ-channel (at least here on my mac), but it would be important that I can use it.
              would be great if there is a workaround for this problem
                On 14/05/2003 at 14:57, xxxxxxxx wrote:
                There are two issues:
                - During displacement VolumeData->ray is NULL (as there is no ray for displacement). Shaders that access the ray without a NULL test may crash.
                - TraceGeometry() cannot work during displacement, as the displacement modifies the geometry itself! The raytracing engine is initialized AFTER displacement calculations are done.
